Loader plumbing
/ Loader plumbing #21
Just for further conversation on some differences in our machines and for posterity. I am posting pics of my 3pt block and like I said these ports may be the correct way to plumb an auxiliary attachment?
It may have the return built in the block to dump into the trans case I have no idea so anybody have an idea please feel free to say it.
My tractor and kenmacs and Domush's are almost identical in so many ways as far as what I know. They may all have the same 3pt block as me no idea about that either.
Also I am familiar with exactly how kenmac has his plumbed and his performance improved once he did it like he said in the other post (and where I stuck my nose in :) ) but thats his info he earned it and will share if and when he wants to. :)
/ Loader plumbing #22
I really haven't considered it a problem but my loader has a hesitation on the curl feature. Not every curl, just every once in a while. Without a pb port is there any other way to plumb that might do away with the hesitation. Might add I don't think I ever actuate loader and 3 point at the same time.
/ Loader plumbing #23
Now that it has been mentioned, i get the curl hesitation sometimes to.
/ Loader plumbing
... some differences in our machines ... I am posting pics of my 3pt block...
I think you have the updated, direct-coupled divider that superceded the external divider block. Same function, different appearance.
Note in this diagram the output from the divider block goes to the input of the 3-point lift.
/ Loader plumbing #25
The main objective with adding additional valves, or a set of QD's for remote operation, is that the flow in open center circuits should be in series.
A simple circuit with no PB on FEL, would be pump, FEL, 3pt, tank.
Another circuit, with PB on FEL. pump, FEL, PB out to 3pt, or another valve with PB.
You could also run a set of QD to the back for a log splitter, pump, FEL, hose from PB to back QD, another hose with QD to 3pt.
If the QD at the back are not being used, then a short jumper for the two QD is necessary.
When you want to use a log splitter, unplug the short hose and plug in the log splitter hoses. The log splitter valve will pass the fluid to the 3pt and then tank.
Most return hoses should go to tank. Below is the exception.
If your FEL valve does not have PB, then the return/tank hose will go to the 3pt.
When the 3pt valve is being used, all valves and hoses up stream are pressurized.
/ Loader plumbing
Thanks! That brings into focus why we get weird interactions. I have bumped orchard limbs, looking back and raising the (heavy) backhoe for transport ... while the loader raised by itself. This loader's valves don't spring back to center reliably when they are pressurized like that.
/ Loader plumbing #27
According to Koyker , a few years ago they supplied a 2 handle valve for the loaders & everything worked well plumbed like most yanmars are. When they changed to the single joy stick with PB ,They say that the PBY should be plumbed to the 3 PT & outlet return to the sump
/ Loader plumbing #28
A couple points of clarity:
1) As JJ says, with any valve added in series between the pump and the 3ph valve, when the 3ph is used to lift something, the entire system is pressurized. In the Hoye diagram, this includes the outlet side of the valve added. The big issue here is that most valves are not designed to have this pressure on the outlet side, 500 psi is a typical max oulet or tank, some are more like 100psi. So, if your system will lift your 3ph load with only that psi, it'll work fine. Probably there is a little safety factor there too, so it could work OK for quite some time, but when you lift that heavy load that drives system pressure to 1500psi or more, the valve could burst or more likely seals will let go first.
2) Power beyond acts just like the outlet (as plumbed per Hoye), except it is designed to pass the HP. In addition, you get an extra return to sump, so you can lower your loader and raise you 3ph at the same time , or lower and dump at the same time, see below.
3) PBYD does necessarily give you loader and 3ph control simultaneously. If you full stroke the loader valve, you will have no flow at the 3ph valve. If you partially stroke it, you will have some flow available, but the fluid will take the path of least resistance and will likely work one of them over the other. Similarly, the if you stroke the loader for both lift and curl fully, the one with the least resistance will get the priority. If you had enough pump capacity, both may work...
/ Loader plumbing #29
I have the 2 handle valve on my allied 195 loader, so I assume by kenmacs info that its plumbed properly, I'f I change to a single control valve guess I will worry with changing it then. This is a very good thread and I don't recall any old threads with this info which is kinda odd with all the information available here.
Can the outlet side of the valve be made to support the higher pressure? Or is that psi rating an internal thing?
/ Loader plumbing #30
I think you must be right that the grey's don't have it (diverter block), otherwise you'd think hoye would use it. Hoye actually sells fittings to bolt to the pump discharge and hp line so you don't have to cut either.
Yanmar Tractor Parts: HYDRAULIC ADAPTER - ADD A LOADER / LOG SPLITTER
Whatever the method of tapping the high pressure, pbyd valves should be used for the loader AND any additional after that (grapple, TNT).
See I like that better than my situation where they hacked my line up BUT then the outlet would have been an issue they would have had to deal with and obviously the in series is the easy way out for some.
With that said there isn't an adapter that I found would fit on the sump suction flange at the bottom of the trany it is a 4 bolt arrangement.
I am in the pre-plumbing design stage of re-doing mine and have looked into the Hoye HP adapter and if I could have an adapter at the sump/suction line at the bottom of the trany case I would re-attatch my HP line back together with a sleeve and silver solder and do it all that way.
It would be so much more sanitary and simple its not funny.
/ Loader plumbing #32
Is there some way to do this and dump upstream of the filter?
I was going to to tie into the suction. Had I done this It would have been ahead of the suction filter. I didn't want to return ahead of the filter
/ Loader plumbing #33
If yours has a PBY port. I would use it to supply the 3 pt & outlet for return to sump. Bad thing is, (in some cases) it's not easy to locate a location for return. If I had not had this plate behind the shifter for my return location. I was going to drill & tap the transmission for a return
/ Loader plumbing #34
Using a power beyond valve is probably the best "text book" way to plumb in a loader but it adds complication to an otherwise very simple system. You have to make a fitting to allow you to dump oil back into the fill cap and on a small yanmar it is hard to keep the extra hose out of the way. It usually ends up pretty messy.
I stand behind our instructions- though I may add a link to this topic for more information. The two hose system is simple and it has always worked well. Koyker sent these same instructions along with every loader they shipped out for many years. Then, for a while, there were instructions that said to plug the power beyond port if you didn't want to use it. I'm not sure what they send now.
It is possible that some valves tolerate this setup better than others but I have never seen a setup that didn't work when plumbed this way. I know of lots of customers that have used this setup for many years without problems. I'm, by no means, a hydraulic expert though. I'm just posting what we have had good success with and what the real hydraulic experts have recommended to us as a simple way to plumb in a loader.
/ Loader plumbing #35
and this is the exact way I was instructed to setup my loader, By the man that provided my new Pump, I was how ever also told from another resource that I could simply remove the PB adapter plug this port, although after having it re-explained and confirmed from JJ, I then decided to Leave the PB adapter and rout the line back to the reservoir/transmission, been working great this way, although I do notice the slow curl at times when working at average engine speed of 1500 rpm's revving it up a bit more does seem to speed up the curl,
/ Loader plumbing #36
i think on the smaller yannies the slow hydraulics is one of its features:D mine is plumbed as shown along with many thousands of others and yes mine has that annoying slow curl(dump) on many an occassion which annoys me no end so i have to rev the ring out of it to get satisfactory hydraulic speed.
/ Loader plumbing #37
A lot of times yes. Many valves have multiple outlets, and one of them converts optionally to PBYD by threading a fitting/plug into the port. See instructions here:
Note they use both "power beyond" and "high pressure carry over", it is the same thing.
http://www.surpluscenter.com/Instruct/I9-7861.pdf
/ Loader plumbing #38
After reading all these posts I conclude I will leave mine as is with the simple hookup. Don't have a power beyond port so I really couldn't do a whole lot of changing without a new valve. Is there a good answer for why we have that occasional hesitation when using the curl feature? I'm confident at least in my case it is not related to dirty screen or filter. I appreciate all you guys with the sure nuff hydraulic knowledge trying to help us out.
/ Loader plumbing #39
That dawned on me also that would bypass the filter this weekend thinking about how I am going to do mine for sure so the sump return is the best way.
I agree since basically most of the oil could be bypassing the filter thru the loader valve and right back in the inlet of the pump except when the loader valve is being operated.
I am wondering if there is some sort of slight restriction by going thru the 3pt the way these that are plumbed in series meaning it isn't a straight thru arrangement?
If there is that would most certainly could explain why there are some slow loaders out here.
I have a buddy that has a 2420D and his VN loader is plumbed with a bypass going into the sump and not in series with the 3pt. So I know for a fact not every single loader out there is plumbed in series fwtw some body somewhere is looking at this differently besides a few of us. My other friend that just bought a VN 1610D has a VN loader and I am not sure how its plumbed but I will be looking the first chance I get.
/ Loader plumbing #40
If you were to put a gage into a tee at the cyl port, you would see if you have any pressure as the lever is moved.
The slow response might be because the land on the spool has not opened the circuit inside the valve to allow fluid to flow to the cyl. This could explain some of it at the start, but the hyd should not hic-up/hesitate in the middle of stroke.
It is also recommended to use the PB port if you have one.
Just about every manufacture says to route the OUT port to tank/reservoir, and there is a good reason for that. Ports on a valve are not made equal, and when they are designing a valve, they specify the tolerances on the ports based on pressure, and that relates to the thickness desired for the ports. In particular, the IN ports and the work ports need to be strong.
There is also something about back pressure and seals in the valve that will affect the normal operation. Some of the back pressure limits are 200 to 500 psi on the OUT ports
If you have a valve with PB as the last valve, you could plug the PB port, and use the OUT port to tank, or plug the out port and use the PB sleeve to pass on the fluid.
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
OK TRUCK & TRAILER SALES PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
OK TRUCK & TRAILER...
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
WALK OVER LADDER (A67714)
WALK OVER LADDER...
2021 Bobcat T770 (A64911)
2021 Bobcat T770...
