California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,827
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
In another thread ...
The loader is in series ahead of the 3-point lift. The 'out' line from the loader's valve goes to the tractor's 3-point input.
I went out and looked at my YM240 (US version YM2000). Its loader was presumably dealer-installed by a factory-authorized Yanmar dealer. (30 years ago when Yanmar had dealers here).
Mine is plumbed according to the Hoye diagram. US Yanmars had a 'divider block' just ahead of the 3-point input. To add an accessory, an internal plug is shifted in the block to route fluid out its lower connector and back in at the upper connector.
This install conforms to YM240 Operation Manual, p 41. "control valves of the implement should be used by connecting the control lines [note plural] to divider block of high pressure line."
My slightly later (US) YM186D has its divider block bolted to a port on the transmission. I found a loopback hose between the divider block's Out and In ports. Other evidence indicates a belly mower or loader was installed in the past. According to this tractor's Operation Manual there shouldn't be a load or loopback attached between the divider block input and output. See JCByrd's post below.
Neither tractor has a sump return line.
Only trying to help here....Hoye's install instructions are flat wrong. They are almost just incomplete, until they specifically say to bypass or plug the power beyond, which makes them down right bad. The outlet port on valves is not usually (i.e. almost never) rated for hydraulic pressure (500psi +). The way hoye sets it up, when the 3ph is used, the outlet port will be passing the hydraulic pressure to the 3ph. Eventually, the valve will fail to work properly, or worse, fail catastrophically. The power beyond is design to pass the pressure to the next service, and also adds another return hose for draining the loader cylinders (lowering a load).
Here's what Hoye recommends on their loader install page for plumbing a loader.Stay tuned this man is onto something PB and returns is the key words. :thumbsup:
