Loader mounted auger
/ Loader mounted auger #1
NonTypicalCPA
SW Michigan
Kubota L3940
Can my Kubota L6060 with a third function remote handle a loader mounted 18-24”auger? I’ve got a lot of trees to plant in the coming year and thought it would be a nice way to dig the holes.
/ Loader mounted auger #2
Yes. Ideally, you should find one that is designed for the flow rate of your tractor. It'll still work with augers designed for faster flow rates, it'll just turn slower.
/ Loader mounted auger #4
Owning a GL,I don't believe you will have enough flow to run off the third function.I run a snow plow and grapple off mine.
Lower flow still works with an auger. It just turns slower. My auger is rated for 7-17 GPM. My machine is rated at 11 GPM. His L6060 is 9.4 GPM.
2024 B and B Fabrication CT3500MRT Towable Reel Tensioner (A61572)
2024 B and B...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
UNVERFERTH 12R30" RIP STRIPPER (A63291)
UNVERFERTH 12R30"...
Wooden Wagon Wheel Chair (A61574)
Wooden Wagon Wheel...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2016 DODGE RAM 1500 4x4 CREW CAB PICKUP TRUCK (A59912)
2016 DODGE RAM...
