Loader mounted auger
   / Loader mounted auger #1
NonTypicalCPA
SW Michigan
Kubota L3940
Can my Kubota L6060 with a third function remote handle a loader mounted 18-24”auger? I’ve got a lot of trees to plant in the coming year and thought it would be a nice way to dig the holes.
   / Loader mounted auger #2
Yes. Ideally, you should find one that is designed for the flow rate of your tractor. It'll still work with augers designed for faster flow rates, it'll just turn slower.
   / Loader mounted auger #3
Owning a GL,I don't believe you will have enough flow to run off the third function.I run a snow plow and grapple off mine.
   / Loader mounted auger #4
Lower flow still works with an auger. It just turns slower. My auger is rated for 7-17 GPM. My machine is rated at 11 GPM. His L6060 is 9.4 GPM.
Truck Absorptions Attenuator (A54865)
Truck Absorptions...
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
NISSAN 60 MAST FORKLIFT (A55745)
NISSAN 60 MAST...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
CATERPILLAR 931E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 931E...
