Loader mount bolts loose
/ Loader mount bolts loose #1
r40kh
Nova Scotia
Kubota M7040
Servicing the M7040 today and decided to check the torque on the loader mount bolts on the LA1153. I found four bolts were loose. Just wanted to give everyone a heads up on this. I had checked these bolts previously within the last year and they were fine. According to the service manual they should be checked on a 50 hour interval so I'll be sure to check mine more often.
/ Loader mount bolts loose #2
Check the lug bolts at the same time.
/ Loader mount bolts loose #3
Very common. Good you caught it before damage occurred!! I check mine often. Caught them loose on my B2920 during the first check. On my L3200, they were still all tight at 50 hrs.
/ Loader mount bolts loose #4
I'll have to check the 7040 and 2920 next chance I get... It is easy enough to do.
/ Loader mount bolts loose #5
I have never found loose nuts/bolts, anywhere, but I still check everything 2X annually. Its a lot easier & less expensive to check than repair.
/ Loader mount bolts loose #6
This is one of the hardest things (maintenance wise) for me to do because it not on any schedule. For most mechanical things, we don't have to check and retighten/torque fasteners on the machines we have. There is though, I think quite a bit of vibration inherent with tractors that may warrant checking fasteners on them every once in awhile.
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59914)
2023 KENWORTH T680...
2021 Bobcat T770 (A64126)
2021 Bobcat T770...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65054)
2001...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
