Loader Hydraulics Dead
/ Loader Hydraulics Dead
paulB, you were not kidding about the ..way more. That was the longest thread in history! I did not notice that i had float before the valve incident, but since I was clueless about float, who knows. Will check out the valve caps and decide if I want to tackle the springs and balls, or live without float and wait for my next service call. Thanks for your help!
Thomas,
Turned out I accidently turned the hydraulic directional from front and rear hydraulics to rear only! Thanks for your help.
/ Loader Hydraulics Dead #23
Von
Hey guys, That little flap on the joystick is for when you take the loader off. It allows you to move only in two directions, this way you don't let the loader down to the floor or move it too fast when removing it. I still have it on my LA350 but never use it. (works too slow!) Hope this clears it up. Also you may want to wire the valve in place so as to not turn it off agian. I had to do mine this way as mine was machined out wrong from the factory. When I got the loader the dealer had the tractor for a week trying to figure out why the loader would not work. When they took the valve apart they found that the roll pin was in the wrong spot and was not opening the valve all the way. So they wired it in position and have not had a problem since.
Von
Re: Von
I knew there must be a good reason they put that flapper there. Good idea about wiring the valve in place. Will do that now that the little stopper rod has broken off.
/ Loader Hydraulics Dead #25
Re: Loader Hydraulics Dead... :eek:)
Glad you found your problem,for thats how we all learn.
Thanks foe your respond also.
Take care and have fun.
/ Loader Hydraulics Dead #26
Re: Von
Von, can you explain better for a dense old man? I don't understand your comment about the flapper. If I pull mine down over the joystick, you can still pull back on the joystick (raise the boom, if the loader is still attached), but you can't go any of the other 3 directions.
Bird
/ Loader Hydraulics Dead #27
Re:loader flap
Bird, In my loader hand book it states that the flap only allows the joystick just enough movement to remove the loader slowly. Mine will allow it to move in roll back and up but not full travel of the joystick. I guess its so that the loader won't jump up out of the sockets too fast when removing it. I know there is a bit of a difference in the B2710 loader and the one on the B8200 so maybe yours only requires the joystick to move in the one way to remove. Hope this helps you to understand it a little better, it would be alot easer if I could show you.
Von
/ Loader Hydraulics Dead #28
Re:loader flap
Thanks, Von, I'm guessing mine's the same; just don't understand why I can't find any mention of it in my manual. I'll have to give it a try, but I didn't think you could move the stick enough to do anything, other than raise the bucket, with that flap in place.
Bird
/ Loader Hydraulics Dead #29
Re:loader flap
I spoke too soon this morning, Von. I set the loader off this morning to do some garden cultivating and experimented with the joystick and that little flap, and when it's pulled down on the joystick, you cannot move the joystick in any direction but straight back. So, it must not be for the same purpose as yours.
Bird
/ Loader Hydraulics Dead #30
I finally have something to contribute!!! LOL The hinged plate on the loader control according to my loader book is for when you are connecting and disconnecting the loader from the frame. It restricts the fluid flow so the hydraulics worl really slowly when lifting the loader out of the frame. If it's in the down position you won't be able to get into the float position.
/ Loader Hydraulics Dead #31
I finally have something to contribute!!! LOL The hinged plate on the loader control according to my loader book is for when you are connecting and disconnecting the loader from the frame. It restricts the fluid flow so the hydraulics work really slowly when lifting the loader out of the frame. If it's in the down position you won't be able to get into the float position.
/ Loader Hydraulics Dead #32
Re:loader flap
Bird, all of the ones I've seen (on L's) have a rubber bushing around the bolt that holds the flap to the bracket. The purpose of this bushing, other than to keep it from rattling, is to give you something to compress against with the joystick, so you can move it ever so slightly forward, left, and right when attaching and removing the loader. Does yours not work that way?
/ Loader Hydraulics Dead #33
Re:loader flap
Well Mark, I had to go have another look, and you're right. I can move the stick side to side, but only if I use both hands and move the stick with one hand while I push on the end of the bolt with the other hand (possibly could be changed with some lubrication). I never did find a way that the stick could be pushed forward, but that's all right. At least now I know what the intent was and why they put it on there, and I also know it's totally worthless and I have no use for it. As long as I keep it up out of the way, I can remove and/or hookup the loader quickly and easily. But I appreciate you guys solving the puzzle.
Bird
/ Loader Hydraulics Dead #34
Re:loader flap
Bird, I noticed the same thing on mine, but also noticed that the mounting bolts holes are slotted to allow the whole bracket to be moved so the very limited motion would be enough to do what it's designed to do. I could be that yours isn't quite far enough forward. Well, if it won't allow you to push the joystick forward far enough to cause the loader to pick itself up out of its mount brackets, then it definitely isn't far enough forward. Ain't these text markup features cool?!!? /w3tcompact/icons/cool.gif
Mark
/ Loader Hydraulics Dead #35
Re:loader flap
I'll bet you're right, Mark, but I'm not going to try to adjust it since the only thing I've used it for, or intend to use it for in the future, is to partially lock the joystick in the neutral position when the loader is off the tractor, and it's adjusted now to do that. And yep, I do like the markup feature./w3tcompact/icons/smile.gif And the last mesage I posted only took 2 full minutes to post after I previewed it and then clicked on "Continue."/w3tcompact/icons/frown.gif
Bird
/ Loader Hydraulics Dead #36
Re:loader flap
I didn't notice any slowness when I posted my message, but while reading yours, I clicked on your name to see how many total posts you've got (165) and it took almost a minute to get the screen. Then I clicked on my name to see the same info (164) and it came up in 5 seconds or so. Strange.
But, unless you just posted another message while I was typing this one, we're even!
Mark
/ Loader Hydraulics Dead #37
Re:loader flap
Well guys, I can see how the flap might be helpful or a saftey feature for taking off your loader but my B21 has one and the loader does not come off. I reread my loader manual and there was no mention of the flap. A friend guessed it was to keep someome from lowering the loader by bumping the control if you wanted to leave it raised for some reason. We may have differnt kinds of flaps in that mine only stops the control lever from moving forward.
/ Loader Hydraulics Dead #38
Re:loader flap
Yep, it sounds like yours is a safety device to keep someone from inadvertently lowering the loader.
Mark
/ Loader Hydraulics Dead #39
Re:loader flap
I use the flap to keep the control stick from vibrating when I am warming up the engine at lower RPM's. At higher RPM when using the tractor it does not shake.
Andy
/ Loader Hydraulics Dead #40
Re:loader flap
That was my own theory. Since my Owner's Manual also mentioned nothing, I figured that it was required by the Feds. A type of lockout device. I briefly searched the OSHA site (http://www.cdc.gov/niosh/homepage.html), but haven't found anything so far. Have some other .gov sites to check, but haven't had the time to research them. Will let everyone know if I find any info.
BTW: If any new owners have doubts about the need, or the effectiveness, of ROPS and belts, check out the OSHA link. Search on 'ROPS'. It will change your mind in a heartbeat!
2022 EZ-GO ELITE...
(48) Closing Wheels off Great Plains Planter (A65640)
(48) Closing...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2020 KENWORTH T680 6X4 T/A  SLEEPER  TRUCK TRACTOR (A59914)
2020 KENWORTH T680...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
