Loader hoses
/ Loader hoses #21
If you go through Discount, get the hydraulax tough(HT) or at least the 100R16 hose. The other hoses don't seem to hold up as well and are much tougher to work with.
I just did all my loader hoses on my L3240 recently after I blew a hose, looked ok on the outside but but still let go.
The tractor sites outside more then I like so I put sleeves on all the hoses for UV protection. Luckily I bought a hyd. hose crimper not too long ago so I can make up my own.
Sent from my SM-G715U1 using TractorByNet mobile app
/ Loader hoses #22
Kinda hard to load when the loader is locked 😜
If the machine cannot yet lift the boom, then you are not going to get kil't by a hose popping. On my payloader, a 36,000 pound machine, I use heavy 5x6" ash cribbing to support the end of the boom and the bucket since a loader lock is not practical for a machine that heavy. Here is a video showing what I did to hold the loader's boom up so we could work on the bucket without getting squished dead like a bug if a hose popped and the loader and the 4,000 pound bucket came crashing down. If I was safer, I'd build up the cribbing stack and then drive the loader boom over the stack and then rest it on the cribbing the support my loader's boom. Anyway, I think it is an entertaining video.
/ Loader hoses #23
When my tractor was new 20 years ago I covered all hydraulic hoses with split poly looming for wiring harness' and just used cable ties at each end to keep them from getting peeled off. My tractor has lived every single day outside since and I've only replaced 2 hoses in that 20 year period. The only 2 hoses not covered are the 2 short ones to my toplink cylinder and I did have to proactively replace them year before last as they showed MUCH cracking as they are short (18") and stay flexed sharply all the time. Those 2 hoses I bought from Surplus center at very reasonable prices. The other 2 I've replaced over the years I had done at local parts stores and they were very expensive in my opinion PLUS they didn't have the exact same fittings and were a real pain to install as they were larger hex size at the bunch on my loader valve and the hose was the next size larger to boot too.
/ Loader hoses #24
On my B7200, the hoses started to fail at 30 years. Been replacing them as they leak. Have had no burst hoses or other catastrophic failures.
/ Loader hoses #25
The loader hoses on my B7800 are original. The tractor has been outside in the desert for 17 years. They still look good, no cracking or bulges. I am concerned that one could fail causing the loader to drop. Cost at Messicks will be almost $500.
Your thoughts on replacement.
Forget it until one fails. There are local shops that make hydraulic hoses in every state I have seen. The connectors are "expensive" and the hose is relatively cheap. The nature of them is they start leaking and show cracks and give you some warning -- not a sudden failure -- unless you mechanically pinch them in a loader joint or something. And $500 is a factor of ten absurd for any one hose. You should be able to replace them for $100 most places.
/ Loader hoses #26
My .2c worth.....if its not broken don't fix it. That said after 17 years having a spare handy might be wise. Not sure about your loader but many on mine are a common length with identical fittings. Are the hoses interchangeable on yours? Maybe get 1 or 2 and some oil handy. Other than that inspect them regularly for weeping at the fittings bulges etc and change then. Oh and like all loaders never stand under a raised one/never swing a raised loader over someone else's head
/ Loader hoses #27
One spare hose is worthless. Normally each hose has a different length and different combination of fittings than another. Like JWR, I do not even think about replacement unless there is failure. And every time, failure is detected because the hose starts to become "wet". That is the sign it needs to be replaced, but even before that, simple inspection normally can identify if a hose has some type of abrasion or kinking or cracking that will turn into a leak. Catastrophic failure? - does not happen unless there is a catastrophic load on a weak hose.
/ Loader hoses #28
When it comes to plumbing their hydraulics I am glad I don't own a Kubota
/ Loader hoses #29
i second surplus center, the only time i buy from napa are when it absolutely has to fit an exact length or i need it right now. i actually have a few generic 1/2" npt hose and some fittings so i can make temp fixes while i wait for a surplus center order to arrive. i have even repaired equipment with their surplus hyd motors,pumps, valves and cylinders all great deals.
/ Loader hoses #30
I found it much cheaper, on my 3930 with Quickie loader to find a local hydraulic shop and have replacements made per sample. About 1/3 the cost of going back to Quickie.
Yup, same here. My local Kubota shop made replacement hoses for a heck of a lot cheaper than that. It's usually not a catastrophic hose failure. More likely starts as a pin hole leak. You'll have enough time to reposition your tractor and move it to a shady spot to pull the hose. The frustration comes when it happens on the weekend when all the shops are closed.
/ Loader hoses #33
A lot of what were hoses on other tractors I've had are steel tubing on the Kubota.
Note: if you don't want to replace all the hoses, consider just replacing the ones that are most dangerous if they fail.
/ Loader hoses
Hey, it looks like you can help me out here. There are 12 hoses involved so at $100 that’s $8.33 per hose. You get them for me and I’ll pay you $200. It’s a quick $100 profit for you. DEAL?
/ Loader hoses #35
Look over all hoses. You'll find that some are more apt to be early fail-ers than others. I've replaced two loader hoses on my 2006 B7800. One was a bit taxed due to the metal tubing getting bent a bit and straining the hose (failing near the connector): I over-sized the length on the replacement to help relieve this situation. Can't recall what happened with the first one, perhaps it had rubbed through? (<- any place where this is seeming to occur one should use a sleeve) In both cases it was more a matter of seeing drips, no catastrophic event/failure. I was completing a project last summer and really straining the loader- kept watching it leak out fluid as I had to get the job done. If operating with a max load and there's no signs of any leaks then there's no reason to replace. One _could_ buy a spare hose if there's symmetry, but otherwise one is just tossing darts as to which is going to fail first/next. Also keep in mind that most everything has a shelf life- life expectancy decreases as any spares sit on the shelf; might not be sufficient enough in the scheme of things, but it's just something to keep in mind (this is why it seems best to have a new hose built rather than one that could have been sitting for a long time on some dealer's shelf).
/ Loader hoses #36
The hoses on my Kubota B20 were rubber over nylon braid. The rubber was falling off and soon the hoses would start leaking. Replaced the first couple from local hydraulic shop. Then ordered 11 from surplus center at considerable savings. All two wire with tuff guard rubber. Had bought a roll of nylon sleeving and used that too even if equipment is stored under cover.
Marcrest BSP449 (A64127)
Marcrest BSP449...
10in Bucket w/ Teeth Excavator Attachment (A64194)
10in Bucket w/...
2018 F-150 4WD (A63688)
2018 F-150 4WD...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
