Loader hook up question
/ Loader hook up question #1
Kubota Greg
I am adding a FEL to my B7100 HST-D. I want to tap the hydraulic block to feed the control valve. Can anyone help me with the following questions...
1. What is the thread size of the plug in the hydraulic block?
2. Can I simply feed the spool valve from the hydraulic block and then simply have the return line feed back to the transmission as a low pressure line?
3. The loader, from a Bolens tractor, it's a Johnson TC-10. I am almost 100% certain that Johnson made this loader for Kubota back in the day who called it a B219. It used it's own pump and the fluid reservoir was in the right side up right. (I will be using the tractors hydraulics) Is it most likely that the spool valve was not a power beyond valve? Meaning if I use this valve, I must use it with the exiting line as low pressure? I'm still learning hydraulics, I only bough my 1st tractor 4 weeks ago.
Any help you guys can offer will be greatly appreciated.
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2025 Ripper Mini Excavator Attachment (A66734)
2025 Ripper Mini...
LEEBOY 8515B PAVER (A67714)
LEEBOY 8515B PAVER...
2013 International DuraStar 4300 S/A Dump Truck (A66736)
2013 International...
x (A68191)
x (A68191)
Unused Hustler Euro Style Loader Kit (A66734)
Unused Hustler...
