Loader help needed
/ Loader help needed #1
Jack6378
Fartrac555
I have a problem with my tractor a farmtrac555. I went to put the chains on and the loader worked slow. I shut it down to lay out the chain but when I started it again the loader would not go up!. During the week I replaced a hose who end was rounded would not screw into the fitting on the driver's side so I replaced it don't know if it has anything to do with the loader not going up.
/ Loader help needed #2
Welcome to TBN & Merry Christmas
I suggest to check hyd oil level to be sure it's at the full mark. Disconnect/reconnect any hyd quick couplers associated with FEL hyd's.
Thanks Mary Christmass to you. I went to check it again and made sure the 2 quick connects in the back were plug in and they were. I started it up and it worked! So I let it run for awhile I think it the hyd. Was cold.
/ Loader help needed #4
Cold alone would not do it in my opinion.
My guess is you possibly had some water in your hydraulic oil that froze or gelled.
Cold hydraulic oil would generally only be slow for a bit and it would warm up fast as it circulated.
Deutz 4-Cylinder Air-Cooled Industrial Diesel Engine (A63689)
Deutz 4-Cylinder...
2004 John Deere 4710 Sprayer (A63688)
2004 John Deere...
Hydrapak 3pt 20' Tool Bar (A64119)
Hydrapak 3pt 20'...
2022 Mercedes-Benz Sprinter 1500 Cargo Van (A61573)
2022 Mercedes-Benz...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
2014 John Deere 644K High Lift Articulated Wheel Loader (A61572)
2014 John Deere...
