Loader Loader dump cylindars not moving at the same speed?
   / Loader dump cylindars not moving at the same speed? #1
93Mustang
Chester County, PA
JD ##@)
I forgot to put the pins in the bottom of the jdqa holder and sort of snapped off the grapple. Was lazy and didn't get off and forgot. Completely stupid... Nothing seemed to bend but I noticed the two dump cylinders were moving at different rates when i went to reattach the grapple. Finally got it reattached - everything seemed ok and took it off. Cylinders still not working at same speed with nothing attached which makes attaching things a real PITA. Did some work with the bucket and disconnected - same issue. Any thoughts on why or what I may have screwed up? No visible damage. Thank you - Dana
   / Loader dump cylindars not moving at the same speed? #2
Nothing is wrong. Hydraulics follow the path of least resistance. Which ever cylinder offers the least resistance will move first and/or faster than the other. Perfectly normal.
Kim
   / Loader dump cylindars not moving at the same speed? #4
As kennyd stated the rod that ties both QA shoes together is only there to solve the cyl timing issue.
   / Loader dump cylindars not moving at the same speed? #6
Kenny, may be correct but I'm not 100% sure. My 300x dump is over 6" off and the pins are fine. Just alot of slop in the holes. I took the whole thing apart just cause I couldn't believe how much play there was. I was planning on ordering a new timing bar since I have new pins.
Matt
Well I checked the pins today and they are still there. Lots of movement though in the whole setup, particularly on the side that is quicker. Guess it is what it is. Can't tell if something is bent but I guess I feel better that this is not uncommon.
   / Loader dump cylindars not moving at the same speed? #8
I have also seen the rod snapped just inside the casting. It was still there, the pins were still there, but it was free on that end.
I haven't done that bad yet, but I did manage to twist the timing arm. Had to block one cylinder and retract the other to get it mostly straight.
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2015 FREIGHTLINER...
SKIDDED MIXING UNIT (A55745)
SKIDDED MIXING...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
