loader conversion
/ loader conversion #1
Bser
I have a 3400 ford with the factory loader that I want to change to a bobcat style quick disconnect. What brand of conversion has the most bang for the buck? I've tried to find a junk skidsteer to rob the plate to adapt myself but have struck out. Open to ideas,suggestions,etc.
/ loader conversion #2
I know there are companies that sell universal skid steer quickmount plates, only thing you have to do is weld some pivots to the back of it that match your front loader. which companies, i dont know... ;)
Are you willing to change all of your existing loader implements too, to keep things compatible ??
/ loader conversion #3
the only problem with that is the Ford has a lot more power than all but the biggest skid steers so be careful what use for attchments and what you do with them
/ loader conversion #5
i contacted ATI for a QA conversion for my older pin style bucket.
mounting plate was like $1800 and weld on plates were like another $1000... WAY to expensive for my tastes.
/ loader conversion #6
They could have just said that they dont support older loader models anymore, instead of scaring you off with crook pricing !! for $2800 you're already halfway, when saving for a brand new loader WITH QA and bucket !
/ loader conversion #8
/ loader conversion #9
I had the same issue with my little Ford 1210 with the standard bucket, and a set of Nursery Jaws. Pain in the neck to swap them. I also have a Bobcat, so I have FEL implements which fit one machine, but not the other. I decided to switch all my FEL implements to universal skid steer attachment. The ATI website shows a parts list for their Tach-all, and I fabricated from that. It works just fine. The most time-consuming was fabricating and assembling the locking pins
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2013 CATERPILLAR D6N LGP CRAWLER DOZER (A65056)
2013 CATERPILLAR...
GAS CYLINDER TRANSPORT BED (A67714)
GAS CYLINDER...
2015 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2015 (INOPERABLE)...
1189 (A65054)
1189 (A65054)
2025 48in. Farm Jack (A66734)
2025 48in. Farm...
