loader control 4110
  • Thread starter $chevelle72
  • Start date
/ loader control 4110 #1
$chevelle72
Guest
my 4110 is a 2004 model with a ml112 fel. the loader controls has gone bad and is built by nimco-controls.We no longer have a Mahindra dealer here. Do the Mahindras still have Nimco cotrols and where can I buy one?
/ loader control 4110 #2
have you considered going to the KMW website (the folks who make the loader) and asking them for a part price?
otherwise, I'd look at Surplus Center.
/ loader control 4110 #3
You MIGHT still be able to get the valve through Mahindra, but it might be a challenge. What is wrong with the valve that you have?
/ loader control 4110 #4
I am working on it for ya.
/ loader control 4110 #5
Can I get a serial # of your loader.
the bottom assembly is broken on one of the spools and the other day I curled the bucket down and it won't curl back up, when I pull the joystick I don't feel any pressure from the pump and no movement of the bucket, but it still works in all other positions..
The serial number on loader is 040313171, model ML 112e.
The numbers on the nimco loader control is
10358-2s
03-48
239555
thanks for all your help guys.
ronnie
/ loader control 4110 #7
Ronnie
I sent you a PM
/ loader control 4110 #8
Hey I need to resurrect this one I'm having the same problem. What was the fix for this? Where to get parts.
/ loader control 4110 #9
I am also having issues with my ML112e loader control. Serial #042816798. Nimco 10373-2S. Float control will not work. Bucket will just start to rise as i am driving. Do they sell rebuild kits? My tractor is a 3510 if that makes a difference.
/ loader control 4110 #10
There are no rebuild kits for these.:(
/ loader control 4110 #11
Thanks for the reply Rick. So do we have to just buy the whole thing or is there a fix for it?
/ loader control 4110 #12
Well I guess I will answer my own question. No you don't have to just replace the whole thing. Take the valve control plungers out of the valve body, take the clip off the bottom of the plunger. Remove the plunger seat, put the plunger rod in the vise and compress the spring seats together. Work the plunger rod in and out, take a wire wheel and clean up the burs on the plunger rod where the spring seat sits. Clean everything up and reassemble. Works good as new for now. Don't know how long it will last, but works for now!
/ loader control 4110 #13
The spring can come off the bottom (bolt comes loose). Remove the cap on your up/down linkage. Likely the bolt backed out and the spring is out of place.
Also clean the crud out of the bottom section.
FYI- this is NOT disassembling the valve, just the bottom cap, so it's quick and easy, even for a newbie :D
If the joystick is sticking, pull the rubber boot up on the joystick and lube the linkages on the top of the joystick. Water tends to get in there and rust up.
- JC
/ loader control 4110 #14
Your not talking about my unit, because the spring is captive by two top hats that are pressed on, not bolts. Then you have the shaft seat that is held on by a snap clip. Not a snap ring, it doesn't have holes for snap ring pilers. Just looks like a big wire rolled in a circle with a gap at the end. And yes one of the rings had came off, but the seat was still in place.
/ loader control 4110 #15
/ loader control 4110 #16
It's a Nimco. Same as yours, but you are talking about a joystick repair. I had to do this as well, but the main problem was the the valve body plunger spring was sticking.
/ loader control 4110 #17
The link was to show you the joystick to compare to yours and the parts that need greased ;)
The caps are on the bottom of the valve, one for the lift and one for the curl. Remove the cap, make sure the bolt is attached and tight and clean out any junk that accumulates in there.
In any case, glad you got it fixed. Happy tractoring.
- JC
/ loader control 4110 #18
Wallace; you sound knowlegable re. Nimco. My 3510 bucket will not roll up. If I tap on top of valve with hammer it will rol up slowly. Can I take Bleed Valve apart, or 'load hold' valve to see if there is a problem? Suggestions?
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
2013 Chevrolet Tahoe SUV (A64194)
2013 Chevrolet...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
2005 Chevrolet Suburban SUV (A64194)
2005 Chevrolet...
2019 JOHN DEERE XUV855M S4 CART (A66091)
2019 JOHN DEERE...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
