Loader loader bucket
   / loader bucket #1
wbj459
farmtrac 300 dtc
Can you adjust the level of a bucket? one of the cylinders is approx. I/4 inch different from the other
   / loader bucket #2
Not really. They work on oil pressure so should equal themselves out. Have you made sure both rear tires are the same air pressure? This will make a difference in the measurements. Considering if you are measuring from ground to bucket, not length of cylinder. Check for worn out bushings or a bent mount.
   / loader bucket
I would guess a bent mount as loaned it out to family member and found out he was using it as a dozer
   / loader bucket #4
Check/tighten ALL the loader frame bolts...sometimes they have a tendency to loosen up, especially on newish tractors...I hit mine with an impact wrench just to make sure. BobG in VA
   / loader bucket
Thanks Bob, I'll give it a try(when it warms up that is)
Copper Eagle Weathervane (A57454)
Copper Eagle...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
30KW GENERATOR (A58214)
30KW GENERATOR...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2020 FREIGHTLINER M2 NON CDL 26FT BOX TRUCK (A59575)
2020 FREIGHTLINER...
