Loader bucket tines & grapples
   / Loader bucket tines & grapples #1
bigsnowdog
Deere 5500 Kubota L245DT, Ferris 3100
What I really need is a grapple for my loader bucket, as I have a lot of as in roughly 250 conifers 30 feet tall I have to cut and move. A minor detail is that I can't afford a grapple just now. Or a chipper. :-(
I am thinking of making some forks or long tines to attach to my loader bucket. I have a John Deere 5500 with a JD540 loader. The loader has a 7' wide, high capacity bucket.
My question: Have any of you fabricated tines for such a task, and if so, what did you use for material? I intend to simply cut lengths of material, then drill the material and the bucket and bolt them on [unless some other, better idea emerges here]. I consider C-channel, or round or square bar. Mild steel or T-1?
Thoughts on this?
No one?
   / Loader bucket tines & grapples #3
have you searched the posts for grapple there are some real good ones I have seen on here couple Ive seen were made of shanks from box blades.
If I build onethats the way Im goin b/c it will save a lot of time cutting out of 1" and then heating hardening and heating toughning.
You will note the post says I can't afford a grapple.
   / Loader bucket tines & grapples #5
the tines for the box blade around here are about $30 a piece I know a sheet of steel is a lot more than that. and forks ha forget about it.
I guess I dont get what your askin tho my mistake.
Do you have some free supply of material to make something or what?
   / Loader bucket tines & grapples #6
I made log forks from leaf springs from a 1 ton truck. Using the center hole and one burned on the end, I mounted to existing buck holes using grade 8 bolts, washers both sides.
I only used two for my JD520 loader w/ standard bucket. They work very well for moving whole trees or logs. I prefer them over my fork attachment for this kind of work. The springs are very tough and have endured a lot of abuse cleaning up after hurricanes. I'd estimate they have moved over a thousand trees.
I do want a grapple something fierce but not sure I want to add the hydraulics to make it work at this point. The new tractor is just on the horizon and it WILL have third function loader and a grapple!
Oh, total investment for the spring forks was about $50, but that was fifth-teen years ago.
   / Loader bucket tines & grapples #7
Any photos?
Bruce
I find myself wondering if the leaves would have too much curve. Or were they fairly flat? I can see a little curve having advantage.
Neat idea, and tough material.
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
