Loader bucket tines & grapples
   / Loader bucket tines & grapples #1
bigsnowdog
Member
Deere 5500 Kubota L245DT, Ferris 3100
What I really need is a grapple for my loader bucket, as I have a lot of as in roughly 250 conifers 30 feet tall I have to cut and move. A minor detail is that I can't afford a grapple just now. Or a chipper. :-(
I am thinking of making some forks or long tines to attach to my loader bucket. I have a John Deere 5500 with a JD540 loader. The loader has a 7' wide, high capacity bucket.
My question: Have any of you fabricated tines for such a task, and if so, what did you use for material? I intend to simply cut lengths of material, then drill the material and the bucket and bolt them on [unless some other, better idea emerges here]. I consider C-channel, or round or square bar. Mild steel or T-1?
Thoughts on this?
No one?
   / Loader bucket tines & grapples #3
have you searched the posts for grapple there are some real good ones I have seen on here couple Ive seen were made of shanks from box blades.
If I build onethats the way Im goin b/c it will save a lot of time cutting out of 1" and then heating hardening and heating toughning.
You will note the post says I can't afford a grapple.
   / Loader bucket tines & grapples #5
the tines for the box blade around here are about $30 a piece I know a sheet of steel is a lot more than that. and forks ha forget about it.
I guess I dont get what your askin tho my mistake.
Do you have some free supply of material to make something or what?
   / Loader bucket tines & grapples #6
I made log forks from leaf springs from a 1 ton truck. Using the center hole and one burned on the end, I mounted to existing buck holes using grade 8 bolts, washers both sides.
I only used two for my JD520 loader w/ standard bucket. They work very well for moving whole trees or logs. I prefer them over my fork attachment for this kind of work. The springs are very tough and have endured a lot of abuse cleaning up after hurricanes. I'd estimate they have moved over a thousand trees.
I do want a grapple something fierce but not sure I want to add the hydraulics to make it work at this point. The new tractor is just on the horizon and it WILL have third function loader and a grapple!
Oh, total investment for the spring forks was about $50, but that was fifth-teen years ago.
   / Loader bucket tines & grapples #7
Any photos?
Bruce
I find myself wondering if the leaves would have too much curve. Or were they fairly flat? I can see a little curve having advantage.
Neat idea, and tough material.
500BBL WHEELED...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
Honda UTV (A56859)
Honda UTV (A56859)
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
GMC 2500HD 4wd Service Truck (A56438)
GMC 2500HD 4wd...
