Loader bucket question (2015)
/ Loader bucket question (2015) #1
driver444
Schenectady, New York
Mahindra 2015 4wd
Just wondering if a 60inch bucket from a 2615 with ML106 loader will fit onto a 2015 with the ML104 loader. Basically, is the arm spacing, and pin size the same? Or is a little welding gonna be in order?
I'm not worried about overloading the front axle, or making the tractor unstable. I just have alot of mulch work coming up, and that extra foot of bucket would be somewhat of a timesaver. It hardly weighs anything. Plus, I have no intention of messing with pressure settings.
I'd keep the 48 inch for the dirt work. It only takes a minute to change them.
/ Loader bucket question (2015) #2
I am pretty sure the spacing is the same, I will check tomorrow.
Thanks,
I know it looked pretty close at a glance, but it's not unlike manufacturers to make something "just a little different" for this reason.
I'll keep my fingers crossed.
/ Loader bucket question (2015) #4
It should work..............according to my measurements the bucket is 43 1/4" outside to outside and 36 3/4" inside to inside.
/ Loader bucket question (2015) #6
Yes it will work. No Question. ;)
/ Loader bucket question (2015) #7
So does the skid steer style quick tach:D
/ Loader bucket question (2015) #8
106 does not have the skid steer QA...:D
/ Loader bucket question (2015) #9
My local dealer said the 106 (and 105) QA /is/ the bobcat style QA now, same as the ML111.
Any other dealers that can confirm that? :)
/ Loader bucket question (2015) #10
Yes the q/tach will fit but its extra weight will take up a pretty good percentage of your lifting capacity. I believe that is why Mahindra doesn't list the quick/tach for the ML 106 and smaller, even though the q/tach will fit on the loaders.
/ Loader bucket question (2015) #11
106 and 105 are completely different animals and are not interchangeable in any way. Skid Steer QA's are not listed for the smaller 15 series due to the manufacturers tractor manufacturers stipulations. On SOME models, there are skid steer QA's that will work as Galen mentioned, but you could run into warranty issues. The 102 and 105 loaders do not have any skid steer type of QA that will fit. There is only the proprietary, pin-on style one.
2024 JCB 3TS8T Teleskid High Flow Compact Tracker Loader Skid Steer (A66734)
2024 JCB 3TS8T...
Has compression. Unknown operating condition. (A64553)
Has compression...
MANIFOLD (A68842)
MANIFOLD (A68842)
2011 SPM SAFETY IRON 100 BBL 10 PUMP MANIFOLD TRAILER (A67714)
2011 SPM SAFETY...
CRATE OF MISC ELECTRICAL WIRING (A68842)
CRATE OF MISC...
1997 FONTAINE FLATBED (A67714)
1997 FONTAINE...
