loaded tire problem
/ loaded tire problem #1
lwalsh
Rockford MI
Is it just bad luck or what? 3rd new tractor, 3 different dealers. My new 2720 has one tire loaded 5 in below the top of the rim. The other is just over half full. Very similar situation with the other two tractors. Doesn't seem that difficult to roll the tire to check fluid level.
/ loaded tire problem #2
The question is about your luck?
Just wondered if this is common. Aparantly it must be a difficult job.
/ loaded tire problem #4
Some people have a terrible time with math and others just simply don't give a rat's ***.
So maybe if you connected a tire pressure equalizer hose between the two tires just before bed time your luck would change over night and you would have equal pressure and liquid in the tires by morning. May not be quite the correct amount but they would be equal.
/ loaded tire problem #5
5" below one rim and the other tire half full? Not sure how you measured this, but 5" below one rim may not be far off from the tire being half full (of course, I don't know what tires you have, or the size).
/ loaded tire problem #6
I never knew for sure how much fluid I had in my tires until I noticed a heavy condensation line the other morning. They are not quite at the same level but are definitely above the tops of the rims. Either I've got too much or I think the dealer owes you some more fluid.
/ loaded tire problem #7
Your tires look right to me.
Rob
/ loaded tire problem #8
the same thing happens to me somtimes one is lower some times they are the same i think the condensation varies.
/ loaded tire problem #9
Well I guess everyone has an opinion, but in mine,, one tire for sure has too much. Rotate the tire until the valve stem is at 12 o'clock, then take out valve stem, let fluid out until air starts coming out, put stem back in. check air pressure, in the tire, re-pressurize with air if needed. check other side too. Some will say to make sure the total rim is immersed in fluid to prevent rust, but the manuals I have seen say to fill to the valve stem and no more. You still need plenty of air in the tire for a "cushion".
James K0UA
/ loaded tire problem #10
They should be they same weight.
If they're filled with the same stuff, which we assume, then they should be filled to the same level.
Most of the time you want them filled to cover the 'steel' wheel to slow corrosion.
/ loaded tire problem #11
My tires have calcium chloride in them and they are tubed. Are innertubes a standard practice when using CaCl?
