LK3054 Battery
/ LK3054 Battery #1
Jim_in_Omaha
Omaha area
LK3054
My battery is getting weak. I was wondering if anyone knew the battery number/type? I looked at the top of it and its a AC/Delco with a 58 on it. Didnt know if there is a generic number. I'm no battery expert. I want to get one before I take out the old one. Have to remove the loader. It was 18 degrees this morning and it did start ok to blade the snow but its marginal now. Lot's of glow plug before cranking..
thx
Jim
/ LK3054 Battery #2
Jim,
For batteries here is what I do.
Measure the height, width, lenght of the existing battery.
Also you need to know the terminal type (top or side mount/round or screw in type).
Get a heavy duty farm/tractor battery with the highest cold cranking amps on the shelf..
I recommend if you go to a auto parts store or TSC for a battery you may want to take the old battery along and compare size and terminals. The last tractor battery I purchased had a $10 core charge. Easier to drop the old battery while you are there and save a later trip back to get your core deposit back..
/ LK3054 Battery #3
Like Vince said; get as much CCA and reserve you can. Also, check to see if the battery you have in there now is as big as you can go. Maybe the battery tray will accept a larger battery.
/ LK3054 Battery
Thanks for the input. I'll have to take the battery out this weekend and match something up.
thx
Jim
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
55 GALLON BARREL TOTE/ OVERHEAD CREEPER (A67714)
55 GALLON BARREL...
3097 (A63117)
3097 (A63117)
Yamaha EF1000iS Portable Inverter Generator (A66734)
Yamaha EF1000iS...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer (A66734)
2023 JCB 3TS8T...
