Liquid Lime/Calcium Anybody tried it?
/ Liquid Lime/Calcium Anybody tried it? #1
Lineman North Florida
Elite Member
LaCrosse Florida
Farmtrac 360 DTC with FEL & John Deere 5093E with FEL ,Kubota SVL 75-2
I have one hayfield that needs the soil sweetened and have been seeing these adds about the benefits of the liquid lime/calcium and while I realize nothing can probably beat dolomite in the long run I'm curious has anyone tried this stuff? And if so what were your results? Thanks. Charlie.
/ Liquid Lime/Calcium Anybody tried it? #2
I'd be interested too. IF someone who has actually used this type product could
post crop results good or bad. Thanks in advance.
/ Liquid Lime/Calcium Anybody tried it? #3
I have only seen it used where things were neglected and a rescue was needed immediately
/ Liquid Lime/Calcium Anybody tried it? #5
It corrected the ph in just a few weeks. but not long lasting nor deep. It was applied to some abused ground my uncle rented and needed help to be used as a pasture for a few years
Regular ag lime last for 3 years but only releases a 1/3 per year but is a hell of a lot cheaper. We applied ag lime the following month for the long run.
I don’t know if it would have much of an effect with deep rooted plants like alfalfa
Thanks, appreciate the input.
/ Liquid Lime/Calcium Anybody tried it? #7
At a class I went to this topic was discussed. If you want immediate results on rented ground then it might be an option however it really is not a practical product or cost effective solution
/ Liquid Lime/Calcium Anybody tried it? #8
I’ve used it in the past. Seemed to work fine. I “road lime” now.
Well I am seriously thinking about trying it in the one 17 acre coastal field, talked to the rep he gave me a price of $16.00 per acre.
/ Liquid Lime/Calcium Anybody tried it? #10
Seems cheap for short term action. I paid almost $70/ton to have ag lime spread in November.
/ Liquid Lime/Calcium Anybody tried it? #11
Times are a changin'!!
We used to need lime applied every two years if you were gonna feed cattle on that pasture.
(This is in Virginia, near Roanoke)
The rain was so acidic, Oldsmobile sent out letters to owners that stated the windshield etching was due to acid rain,, NOT defective glass. That was in the mid 1980's.
It is different now. They have shut down the coal burning power plants up wind of my home.
The acid rain is gone.
I did some "serious gardening" in 2021 and 2022.
I checked the rainwater pH weekly, or whenever it rained.
I also stored rain water captured off my shed roof. All of the water was 7.0 pH,,
It was so neutral, I could change the pH of a gallon of water one full point with two drops of lemon juice!!.
I did not want to change the pH of my soil,,
Well, it turns out, that the rain is now 7.0 neutral pH!! :eek:
I do not know when it changed, but, my soil pH is rising so much, that it needs sulfur for some crops.
(most plants prefer slightly acidic soil)
The local county AG rep is still recommending lime,, there are other benefits to lime other than pH.
BUT, as far as pH,, I would DIY my soil tests before I spent a nickel on lime.
I am positive that lime is getting recommended a LOT based on history, rather than chemistry,,,
Spend the time, effort, and the few $$ for an Amazon available soil test kit.
/ Liquid Lime/Calcium Anybody tried it? #12
I'd be interested to know if you see any results. You are not talking about a lot of money if it doesn't work. I would suggest you leave a skip somewhere in the middle of the field to see for sure if you notice any difference.
My guess is that if you see any difference, it will be very short lived. Changing the pH of soil is not going to happen overnight. It took millions of years to create the soil, you're not going to change it overnight.
Another option you might consider is using pelletized lime. It is a lot easier to apply than regular 'ag lime'. I have used it a few times at a rate of 200 lbs. per acre. This is also a temporary fix. You would probably have to apply it every year.
Even the 'ag lime' is usually a temporary fix and needs to be applied every 2-4 years. It all depends on your soil test results, and what the soil testing lab recommends.
A gallon of their product to the acre " Super Lime Plus " they call it, at $16 per gallon I think I am going to try it in 1 field anyway, I have drug around and waited a little late to go with ag lime I should have done it back in November of last year but I will try to stay on top of it and hit it this winter.
Yeah, I am pretty sure if it works at all it will mostly be because of what the plant soaks via leaf when I spray it and the a little through the root but for the price I think it's worth a shot, I would be really surprised if it actually changes the PH at all, another good thing is that they have a plant location about 50 miles South of me so I will just run down there and pick it up and save the shipping charge.
/ Liquid Lime/Calcium Anybody tried it? #15
Its very cheap
/ Liquid Lime/Calcium Anybody tried it? #17
Wish they'd just post their prices. Considering running a test. Maybe 5ac using
a liquid and 5ac using pelletized. Sock the N to all ac at green up time and see which
little patch does the best (if any difference). Pelletized will need to be put down fairly
soon. Liquid treated as a foliar spray for existing grass stands?
/ Liquid Lime/Calcium Anybody tried it? #18
Talked to one of their reps a few weeks ago at the Southern Farm Show in Raleigh NC. After some quick calculations, the cost was near the price of the ag lime by the time you factor in the cost of the shipping and equipment to spray the liquid.
I talked to a rep yesterday and since they have a place about 50 miles South of me, I will just run down there and pick it up, also the sprayer I use has 3 different spray nozzles and he told me that the liquid nitrogen nozzles would work good, but that they didn't recommend using the herbicide nozzle tips.
/ Liquid Lime/Calcium Anybody tried it? #20
I sprayed mine myself and thought is was pretty easy.
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
CASE 610 Sprayer System 2000 Gallons (A61307)
CASE 610 Sprayer...
2019 Deere 35G (A53317)
2019 Deere 35G...
2017 JOHN DEERE 323E SKID STEER (A60429)
2017 JOHN DEERE...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
