Liquid filled gauges
/ Liquid filled gauges #1
mobilus
North Texas
Kubota L2800 HST 4WD
Why are some gauges liquid filled and some not? Is there a rule of thumb as to the choice? And...why the bubble, is it for fluid expansion?
/ Liquid filled gauges #2
Liquid filled gauges help to buffer the shock from vibrations and operating on rough terrain. I only use glycerin filled gauges on my air blast sprayers for example.
Gauges used on stationary machines, say a well pump, don’t need the shock resistance.
/ Liquid filled gauges #3
Liquid filled gauges are also used when you need protection against pulsation and pressure spikes. They are used for very high pressure applications. I use them on my high pressure air tanks that hold pressure up to 4500 psi. Forgot to answer the bubble question, it is there to help relieve internal pressures to make sure the gauge shows an accurate reading. If it was completely filled with liquid there would be no room for the liquid to expand and contract with pressure and temperate changes.
Unverferth 330 (A64126)
Unverferth 330...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
3pt Counter Weight (A64127)
3pt Counter Weight...
2014 Ford Explorer (A62613)
2014 Ford Explorer...
20ft trailer (A61569)
2014 Chevrolet Traverse (A62613)
2014 Chevrolet...
