Linear Actuator for ct120 grapple
   / Linear Actuator for ct120 grapple #1
ticolawnllc
Bob Cat CT120
My bobcat ct120 can lift about 400 lbs. could a Linear Actuator with a lift force of 200lbs work for a thumb on a bucket. Mostly to hold brush on the bucket for traveling. I don't intend to lift logs with the bucket tilted down position.
Putting a diverter valve in seems like a lot of work money. I don't know anyone who can put one in and frankly I don't want to.
I found one for $58 and I'm going to see what it can do. It has. 12" travel I hope it's enough.
   / Linear Actuator for ct120 grapple #2
From what I can see online, a 12" stroke 2000# linear actuator would take between 24 and 48 seconds to move the 12" which seems like a long time.
A lot of people have learned the hard way that the force on a thumb from a curling backhoe bucket is much greater than they expected. Things usually don't like compression loads unless they have excellent pivoting connections on each end as a connection with friction under load puts a bending force on the push rod resulting in damage.
Are we taking about a backhoe bucket or a FEL bucket? Your use of the word thumb is what has me confused.
If it is a FEL and you are talking about a grapple to hold the brush in the FEL bucket, how are you going to get power to the actuator when the loader arms are going up and down without them being ripped off? You would need a 25 amp fused circuit.
Dave M7040
   / Linear Actuator for ct120 grapple #3
It seems like a painfully slow process. I think unless you're very delicate with it you'll bend it.
From what I can see online, a 12" stroke 2000# linear actuator would take between 24 and 48 seconds to move the 12" which seems like a long time. A lot of people have learned the hard way that the force on a thumb from a curling backhoe bucket is much greater than they expected. Things usually don't like compression loads unless they have excellent pivoting connections on each end as a connection with friction under load puts a bending force on the push rod resulting in damage. Are we taking about a backhoe bucket or a FEL bucket? Your use of the word thumb is what has me confused. If it is a FEL and you are talking about a grapple to hold the brush in the FEL bucket, how are you going to get power to the actuator when the loader arms are going up and down without them being ripped off? You would need a 25 amp fused circuit. Dave M7040
it's for the FEL
I didn't know they moved that slow. Non the less it seems like a cheap experiment. I hope. Lol. You know cheap turns expensive some times.
I do tree removal and the ct120 is great because it fits in back yards and it leaves little rutting. I've thought of getting a midsize steer but I'm afraid it won't fit in a lot of places and it will rip up yards. Obviously with third function for grapple use.
I can't justify keeping both. If I put any money into equipment I'll get a mini excavator with a thumb.
If it is a FEL and you are talking about a grappl to hold the brush in the FEL bucket, how are you going to get power to the actuator when the loader arms are going up and down without them being ripped off? You would need a 25 amp fused circuit. Dave M7040[/QUOTE]
I was going to run a 3 way toggle switch with a 25 amp mini fuse in the line. The rout for the wiring, Honestly I haven't thought that far.
I have a collection of old extension cords. One of the three wires are broken so they are no good any more for anything else. I'll test the wire to make sure I don't use a bad one
   / Linear Actuator for ct120 grapple #8
I falsely read 200 pounds for 2000 pounds. I think it's severely underpowered now. My grapple doesn't bite hard enough to suit me and assuming it had 2" bore cylinders at 2600 psi that's about 8100 pounds of push. I could calculate it fairly accurately by taking some measurements, but just taking a guess the closing pressure at the tip is about 1/4 that much. I want to build a grapple with about a 4" bore cylinder, but it's not practical because of the strength it would have to be not to self destruct. image-623462789.jpg
You're going to need a pretty heavy cord. The typical 14 gauge won't work.
I just want to make sure we are talking about the same thing. It's 200 lbs of force. Not 2,000 lbs of force. One of my mowers came with an Linear Actuator to move the deck hight and it ran off of 15 amp fuse. The deck was like 100 lbs at least. I know the power it will provide is going to disappoint. I'll look up the specs and post.
   / Linear Actuator for ct120 grapple #10
I realized my error shortly after posting and edited my post. 14 gauge would work fine. About 5 amps is what I've seen for 200 pound actuators.
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2019 CATERPILLAR 259D SKID STEER (A52709)
2019 CATERPILLAR...
2020 DRAGON ESP...
2020 KENWORTH  T800 KILL TRUCK (A58214)
2020 KENWORTH...
2022 Horizon Trailer (A55973)
2022 Horizon...
Yard Machines Tiller (A55973)
Yard Machines...
