Lincoln SP-175T Question
/ Lincoln SP-175T Question #11
My guess is rusty wire. I just pulled my Miller 175 out to use this past wkend. I hadnt used it in over a year. I probably had to strip off close to 100ft of wire before it would feed properly. Even then, it would weld fine for a while and then start sputtering again. Feeding out extra wire and you could see more rust spots. If your machine has been setting around unused for a while, take a good look at the wire. With only a lb left on the spool, you might be money ahead to just go ahead and buy some new wire.
/ Lincoln SP-175T Question #12
Go to your welding supply store and get a bottle of wire lubricant , it's non silicone and squirt some on the wire, and leave it on. Then get a clip on wire cleaner, they are steel wool with metal clips that fit on the wire. Squirt the lubricant/cleaner on the wool. This will help a lot.
2014 RAM VAV 2000 TRAILER MOUNTED VACUUM MACHINE (A59823)
2014 RAM VAV 2000...
2005 Bobcat 435 (A60462)
2005 Bobcat 435...
MMS 800 Remote Control Lawn Mower (A60463)
MMS 800 Remote...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
TEST YOUR BID BUTTON! (A62130)
TEST YOUR BID...
2016 Jeep Patriot SUV (A61569)
2016 Jeep Patriot...
