Limiting depth of post hole digger
   / Limiting depth of post hole digger #31
Having PH digger auger corkscrew into soil will not happen if tractor operator eases 3 pt control lever forward in small increments with engine at 1200 rpm's(little ABOVE IDLE) not matter what type of soil one is attempting to drill a hole into.
Yeah, I've been wondering myself how a 3 point hitch can allow the auger to corkscrew down farther than what the 3 point hitch is lowered to without the front end of the tractor lifting up?
Thanks for a lot of great info guys. I think it is just going to be a learning curve for me. I have used tractors beforehand, but never a PHD on a 3point. The examples of different soils, I believe, has a lot to do with my situation. It was the end of the day, had just finished assembly of the PHD, and wanted "to try it" . Probably my first small mistake.
For the life of me, I can't remember if I was just nudging the 3 point down, or pushed it all the way which allowed the auger to screw in about 12", stalling the tractor. I know the rpm were low at that time (tractor idles at 1200), so maybe 1500 tops. After it freed up from about that 12" depth, I bumped the throttle up thinking it was too low and that was why it stalled (not enough power).
Remember, this is a 25hp SCUT, max rpm is at 3300, 540 pto is at 3050. The highest I went was about 2200.
My only other experience with using a "larger PHD" was in very rocky (shale) soil, and you had to run it full throttle just to go a couple of inches. Granted this was a 2man auger, not 3 point.
After all the discussion here, I think the basis of my issue was lowering the PHD to fast and not being prepared for when it "dug in". I have not been able to get to try it again, but I will definitely post my results.
   / Limiting depth of post hole digger #33
lol....your lucky.....I have broken mine on every joint because I have to add weight & even then it takes forever. I have added so much welding and plates now, I hope to make it past 2 holes before something breaks :)
If you have draft control, use it to limit depth, otherwise, learn to use your hydraulics with more finesse, or, adjust hydralic speed so it moves slower, I also do not see the need to rev too hard.
If the front is lifiting up, then you prob need more weight, or a bigger tractor, sounds also like doing by hand may be possible.
Crazy thing is that I have one of the little upright 2 stroke 1 man augers from TSC. IT HAS A 4 " auger. You will be lucky to do 3 or 4 holes 24" deep in a day, that's including filling w/ water to loosen it up. That's why I got the 3 point one...getting to old to be beat up like that. Now it's the opposite, the auger wants to go back to China:D:laughing:
   / Limiting depth of post hole digger #35
I agree. This has been pointed out several times in this thread. ;)
By easing the PHD down in small increments, I have never seen or heard of a 3Pt hitch PHD pulling the front end of a tractor up in the air while the auger continues to screw itself into the ground. :D Without pushing the 3Pt control lever further forward, the auger just can not go any deeper than the operator allows.
   / Limiting depth of post hole digger #36
Now living where there are too may rocks and roots, I've never tried this. If I lived where there was "screw-in" soil, I would make this modification and see what happened.
A sharpened strap, maybe 1/4 x 1 1/2, welded between the bottom flight and the one above, like the blue shape in this photo.
I think it would stop the screw-in problem, if you don't have rocks to get trapped.
Bruce
   / Limiting depth of post hole digger #37
That probably depends on the tractor....some probably should not be doing holes :)
   / Limiting depth of post hole digger #38
I have one of them too....ironically it works the same, I have too much rock and an old PHD setup.....but the person it came from, used to use a second tractor FEL to push down in soil without the rock I have....so, I think the auger is not too great, I welded a pipe and put 20kg weights x 4-6 on it, works much better then, but that stresses everything else.
You will work out a method, at least your not doing a few rounds in the boxing ring with the manual one :)
   / Limiting depth of post hole digger #39
I fully agree. I probably did a thousand holes in clay and maybe got stuck twice. My only issue was having to sharpen the auger a few times until I had someone hardface it. Bigger tractor.
   / Limiting depth of post hole digger #40
Seeing my old International can lift over 2000lbs and prob weighs double its lift, I doubt I could get it stuck, but if I did I know the fame and supports etc would break if you kept lifting the lever up, I should have done photos of each time the tractor broke the digger gantry and frame and lifter and some welds, would have provided some comic relief, I think I got one 9 inch hole to about 16 inches deep......I have a new type of soil down here, cement soil.....ba ha ha
Gonna wait for some rain....
I really wish my auger would try to go home like his :)
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
