Limiting depth of post hole digger
/ Limiting depth of post hole digger
I remember that red shale when I lived in Bucks Co, Pa. You would have a hard time going just a few inches without hitting it. Been thrown off of a two man auger in that stuff!:laughing:
I'm not kidding that there are no rocks in my soil here. My property is about 3/4 mile from the base of a mountain, which is just about all rocks. When I dug our septic, went down 6 1/2' and not one rock.
The tip on the auger is about 6" long, a tight spiral from about a 1/2" up to 2 1/2" . This thing just immediately digs and screws itself in about 6" almost within a second or two (pretty much reaction time to lift it back up). The first "dig", I was able to lift the auger and clear the dirt. The second time back down the hole for the next 'bite', it just continued to dig in, maybe I took too long to lift.
As for the 'drop rate valve', I haven't adjusted that nor was I using it, only the 3 point lever. The auger doesn't walk or move from where it is placed, it just immediately screws itself in. Digs straight down.
Didn't get a chance to play with it again today. Hopefully tomorrow, using some of the tips from here. I'll post my escapades afterwards....wish me luck.
Clarification,
Bought Stihl drive head and two augers, used from rental yard $200.
White RS Hyd motor, 2 hoses, power beyond valve next to loader valve $ $300.
Misc iron in shop, simple frame, short pieces 2 x 5 tube to slide over pallet forks. Hardly a huge investment. To date, 400+ fence posts installed
Out here the rental yards charge crazy prices for the used and abused equipment. There is just about nothing available in a two hour radius... And I mean nothing more than a lawn tractor or chain saws. About the only equipment is very large mining equipment. If you want a good laugh, just go on Craigslist in Albuquerque....pretty much junk only. Sorry to be a little testy earlier...
/ Limiting depth of post hole digger #23
Someone mention using a post hole drill to make fence post holes and that should NEVER be done. Frost action will pull the post back out because the soil has been loosened on the sides of the posts. Fence posts should ALWAYS be driven into the ground.
Most of the time I use my backhoe on my log trailer to dig posts because rocks do not stop that, but I can install a post hole drill on my log trailer too. Because my grapple rotates in either direction, 360 degrees, I can swing my log loader around and bore a hole, and if it gets jammed, just back it out by reversing it. This works really good, so for people who want to do a lot of post holes, a post hole driller on a boom is a much better choice.
/ Limiting depth of post hole digger #24
Post pounders dont work here in Colorado. The clay is to hard & posts just break, even if you are in an area with no rocks like me. I haven't tried personally but have heard that from my dealer (he won't sell em) and a few others that have tried them over the years. I was keeping an eye out on Craigslist for em for a while & saw 3 in as many years, 2 of which were at least 1 state away.
I've had no issues with my posts coming loose in the 4 years since I put in the first new fences. I tamp them in hard in 6" lifts though.
When I pulled the old posts I couldn't tell the difference between the 1/3 of them th as t were cemented in vs ones in dirt until they were out of the ground. I'd either see the cement on the post or sometimes a cement hole in the ground in front of the tractor. There were several old posts I couldn't pull with my L3200 (1,200lbs rated lift, probably several hundred lbs more actually & I was pulling with the back of the bucket for better lift geometry). Several of those broke trying to wiggle them out. The ones of those I checked were not in cement. Those posts had been in for years if not decades.
/ Limiting depth of post hole digger #25
I have only used one or two man augers in the past, this is my first 3 pt PHD. I have watched numerous videos and read numerous posts. I thought I was well prepared to dig my first hole....wrong. I'm using a 9" auger, standard length. Tractor is a 25hp SCUT.
I had the throttle about 22-2300 rpm, dropped the 3 pt a little and the auger dug right in. I lifted it after approx 6-8 inches in, lowered it again trying to do the same, but it screwed in about 8-10 inches. When I immediately tried lifting, but it just stalled the tractor. Restarted the tractor and tried at full rpm at 3000. It just continued to dig in. When it went to full depth, (couldn't go any further, gear box at ground level), it just excavated all the dirt and freed itself up, about a full 48" deep.
The dirt is very dry clay, no rocks or roots at all. I was actually surprised at how easy it screwed into the ground.
I only have to go 24" (30" max) deep on the holes so, my questions:
1) Can I set up a mechanical stop on the 3 point lever to only lower the 3 point to a predetermined position or will the auger continue to just pull it down? I'm hoping that once it hits that "stop point", the auger would just free itself up like it did in the first attempt.
2) What throttle setting should I use? It seemed that at a lower throttle setting, it didn't dig in as fast, but I had no power to lift.
3) I have looked at purchasing a "compact" auger which is only 32" long, but really don't want to spent $140 for another auger if question #1 would work.
Any help would be very much appreciated. Thanks
Why are you operating the engine at max throttle while auguring ? That is a recipe to quickly get into trouble . Idle and just feed it a little depth at a time or she will get away on you.
/ Limiting depth of post hole digger #27
"Lifting" is the problem. You shouldn't have to lift. Rather drop the 3-point just a little bit at a time. Nudge the lever downward just a little each time. And of course as others have said, keep the engine RPMs low.
/ Limiting depth of post hole digger #28
Same as my experience. My very first attempt along a fence line with the 3-point post hole digger buried the 12" auger to the gear box. After 1 hour effort, finally got extraction of the auger and did a shear pin replacement. It became very clear to me that soil type was critical.
1. Hard moist clay will almost always bury the auger. Need to auger down slowly and constantly lift every 3 inchs to clean out the hole. Using this method; about 1 in 5 holes still will bury to the gear box.
2. Sandy soil or sandy loam, never seem to get stuck. Holes go down in 5 mins and every one of them an easy success. Sandy soils make you look like an instant expert. Never get stuck. 3pt easily lift out of the hole everytime.
Layered soils are most challenging. These may have 1-3 feet of sand over top deeper clay. The sand augers easily....and then ZOOM...you hit the clay and buries the auger quickly. Clay soil is your enemy everytime.
/ Limiting depth of post hole digger #29
After reading previous comments; I would clarify the post holes being drilled are for 8 feet long 8" diameter treated wood posts spaced every 60 feet and set in concrete at 30" depth. Fence steel end posts are also drilled and set into concrete. T-posts are set every 10 feet, and these pounded 30" deep using a Rhino fence post driver. Each T-post takes 3 minutes to drive to proper depth independent of the soil type. The fence is typical 60" field fence. I run a single string of barb wire at top of the field fence.
/ Limiting depth of post hole digger #30
Having PH digger auger corkscrew into soil will not happen if tractor operator eases 3 pt control lever forward in small increments with engine at 1200 rpm's(little ABOVE IDLE) not matter what type of soil one is attempting to drill a hole into.
/ Limiting depth of post hole digger #31
Yeah, I've been wondering myself how a 3 point hitch can allow the auger to corkscrew down farther than what the 3 point hitch is lowered to without the front end of the tractor lifting up?
Thanks for a lot of great info guys. I think it is just going to be a learning curve for me. I have used tractors beforehand, but never a PHD on a 3point. The examples of different soils, I believe, has a lot to do with my situation. It was the end of the day, had just finished assembly of the PHD, and wanted "to try it" . Probably my first small mistake.
For the life of me, I can't remember if I was just nudging the 3 point down, or pushed it all the way which allowed the auger to screw in about 12", stalling the tractor. I know the rpm were low at that time (tractor idles at 1200), so maybe 1500 tops. After it freed up from about that 12" depth, I bumped the throttle up thinking it was too low and that was why it stalled (not enough power).
Remember, this is a 25hp SCUT, max rpm is at 3300, 540 pto is at 3050. The highest I went was about 2200.
My only other experience with using a "larger PHD" was in very rocky (shale) soil, and you had to run it full throttle just to go a couple of inches. Granted this was a 2man auger, not 3 point.
After all the discussion here, I think the basis of my issue was lowering the PHD to fast and not being prepared for when it "dug in". I have not been able to get to try it again, but I will definitely post my results.
/ Limiting depth of post hole digger #33
lol....your lucky.....I have broken mine on every joint because I have to add weight & even then it takes forever. I have added so much welding and plates now, I hope to make it past 2 holes before something breaks :)
If you have draft control, use it to limit depth, otherwise, learn to use your hydraulics with more finesse, or, adjust hydralic speed so it moves slower, I also do not see the need to rev too hard.
If the front is lifiting up, then you prob need more weight, or a bigger tractor, sounds also like doing by hand may be possible.
Crazy thing is that I have one of the little upright 2 stroke 1 man augers from TSC. IT HAS A 4 " auger. You will be lucky to do 3 or 4 holes 24" deep in a day, that's including filling w/ water to loosen it up. That's why I got the 3 point one...getting to old to be beat up like that. Now it's the opposite, the auger wants to go back to China:D:laughing:
/ Limiting depth of post hole digger #35
I agree. This has been pointed out several times in this thread. ;)
By easing the PHD down in small increments, I have never seen or heard of a 3Pt hitch PHD pulling the front end of a tractor up in the air while the auger continues to screw itself into the ground. :D Without pushing the 3Pt control lever further forward, the auger just can not go any deeper than the operator allows.
/ Limiting depth of post hole digger #36
Now living where there are too may rocks and roots, I've never tried this. If I lived where there was "screw-in" soil, I would make this modification and see what happened.
A sharpened strap, maybe 1/4 x 1 1/2, welded between the bottom flight and the one above, like the blue shape in this photo.
I think it would stop the screw-in problem, if you don't have rocks to get trapped.
Bruce
/ Limiting depth of post hole digger #37
That probably depends on the tractor....some probably should not be doing holes :)
/ Limiting depth of post hole digger #38
I have one of them too....ironically it works the same, I have too much rock and an old PHD setup.....but the person it came from, used to use a second tractor FEL to push down in soil without the rock I have....so, I think the auger is not too great, I welded a pipe and put 20kg weights x 4-6 on it, works much better then, but that stresses everything else.
You will work out a method, at least your not doing a few rounds in the boxing ring with the manual one :)
/ Limiting depth of post hole digger #39
I fully agree. I probably did a thousand holes in clay and maybe got stuck twice. My only issue was having to sharpen the auger a few times until I had someone hardface it. Bigger tractor.
/ Limiting depth of post hole digger #40
Seeing my old International can lift over 2000lbs and prob weighs double its lift, I doubt I could get it stuck, but if I did I know the fame and supports etc would break if you kept lifting the lever up, I should have done photos of each time the tractor broke the digger gantry and frame and lifter and some welds, would have provided some comic relief, I think I got one 9 inch hole to about 16 inches deep......I have a new type of soil down here, cement soil.....ba ha ha
Gonna wait for some rain....
I really wish my auger would try to go home like his :)
HYDRAULIC CATTLE SQUEEZE CHUTE (A60736)
HYDRAULIC CATTLE...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
JOHN DEERE 850J WH CRAWLER DOZER (A62129)
JOHN DEERE 850J WH...
2004 JOHN DEERE 624J WHEEL LOADER (A62129)
2004 JOHN DEERE...
