Limiter chains too long?
/ Limiter chains too long? #1
To20Chris
Platinum Member
Hereford, PA
LK3054
I tried to put my Woods Dixie Cutter (M5) on the LK3054 today (I normally use it on the TO20). I found that with the narrower rear and R4s that lift arms were going to be into the tires. I could swap the pins so they face inward, which would probably be enough to keep the arms off the tires. Do you think this is worth it, or should I just put together some sorter limiter chanis? Anyone ever try mounting something with inward facing pins? Any other suggestions?
/ Limiter chains too long? #2
I have the pins facing inward on my 78" Lucknow blower and my backblade.
It seems easier for me to mount the arms with the pins facing inward. I have a Cat II three point so the arms are more akward.
/ Limiter chains too long? #3
Shouldn't be a problem reversing the lift pins 180 degrees, I've seen several implements configured that way. But why not just get a bolt cutter and take a few links out of the chain. I put a quick link in mine, so I could adjust the span of the lower arms. I open the quick link, hook up the implement to the TPH, pull the lower arms in tight, hold them there with the quick link.
//greg//
/ Limiter chains too long? #4
I've swicthed all my implement's pins to the inside for my B2400. It's much easier to install and remove from 3pt arms this way, especially the heavier implements. It also requires less adjustment of my check chains
/ Limiter chains too long? #5
</font><font color="blue" class="small">( I found that with the narrower rear and R4s that lift arms were going to be into the tires. )</font>
Chris, I don't understand why that would be happening on your 3054. I don't have that problem on the CK20 and it's certainly as narrow, with R4s. Does your tractor have the sway limiter chains on each side? Are they too long? I wouldn't think so. Are you saying that when you hook up the pins, the lift arms are just too wide and touching the tires and that adjusting the chains would make no difference? That seems very strange to me. I wouldn't think your pins are set any wider than my Howser cutter. I wish you had pics to show so I can see what you mean. thanks, John
I'll try to get some pictures tomorrow. The width of the frame the pins are mounted to is 25.5", which is similar to another implement I measured. The arms will slide out to the clip pins, so that effectively makes it wider. When mounted with the pins outward, the limiter chain will allow the arm to move over to the inside of the (opposite) wheel. The limiter chain has a real nice turn-buckle that takes up most of the length of the chain, so you really can't shorten it up too far. I attached Kioti's picture from their website.
I'm going to have to take a good look tomorrow and see if everything is as it should be - like that all the arms are in all the right holes, etc. I had a 5yr old talking at me non-stop while I was trying this today, maybe I missed something. /forums/images/graemlins/laugh.gif
/ Limiter chains too long? #7
Maybe I misunderstood. Don't you have a horizontal chain connecting the two lower lift arms from the INSIDE ? That's where I put my quick link so that I can pull them TOWARD each other. That keeps the ball ends off the lynch pins too.
//greg//
/ Limiter chains too long? #8
</font><font color="blue" class="small">( I'll try to get some pictures tomorrow. The width of the frame the pins are mounted to is 25.5", which is similar to another implement I measured. )</font>
That's a pretty standard measurment and it should go on without hitting the tires. Are you sure you have the chains and the lift arm brackets in the proper holes? There are three holes to choose from. Try moving the chains to another hoe and tightening or loosening them till you have no sway at all and see if that makes a difference. I see no reason that mower shouldn't go on with the pins as they are and not hit the tires. If all else fails, have a welder remove some links from the chains. John
Never thought of that - I may have to try it, as it always buged me that they ride out on the pins.
OK, it was set up by the dealer with the lift links and limiter chains on the inner set of holes. I just moved it to the outer ones - I haven't put the cutter back on yet, but I'm sure it will be fine now. Should have been paying more attention! /forums/images/graemlins/blush.gif I took the opportunity to grease all the pins anyway.
Thanks for the help guys!
/ Limiter chains too long? #11
Daryl, are you using CAT1 tools with bushings? I have CAT1 and CAT2 lift (4ea, sway/no sway) and top link holes and find it difficult to hook up CAT 1 stuff in CAT1 mode . The top link seems too long for CAT1 stuff especially. I've thought about trimming top link tube so I can adjust shorter, but afraid I might ruin threads. Guess I should run 2 seperate top links. Wondering if you have same problem that you've found cure for?
/ Limiter chains too long? #12
MMM:
I don't have any problem whatsoever. The 5030 came with pins and bushes for CAT2 to 1. I bought a bunch of extra bushes just to have in the tool box. My top link has never been a problem at all. I don't have sway chains on the lower arms. Kubota uses a telescoping tube arrangement with a really wide range of adjustment.
I usually leave the bushes on the pins on the CAT 1 implements. As a matter of fact, I spot welded them on. That way, I don't have to fiddle around with them when I hook up. The only time I felt that the top link was too extended was when the Lucknow 78 is on. To level the blower, the TL must be almost at full extension.
The whole 3 point on the 5030 is very adjustable. When I am pulling the spreader or the MoCo or a rake, I remove it entirely. That way, the arms don't get in the way of the tongue swing. 4 lynch pins and it's off the unit.
2001 Challenger 35 ton Flatbed Lowboy Trailer, VIN 1W8B21D261S000473 (A61166)
2001 Challenger 35...
2004 CATERPILLAR D5N XL HIGH TRACK CRAWLER DOZER (A62129)
2004 CATERPILLAR...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
DELTA RADIAL ARM SAW W/ ELECTRIC BRAKE (A62131)
DELTA RADIAL ARM...
2016 Kenworth T800 Tri-Axle Dump Truck (A61568)
2016 Kenworth T800...
Fork and Frame Mini Skid Steer Attachment (A61567)
Fork and Frame...
