Limited slip differential versus Hydrostatic traction control (HTC)
   / Limited slip differential versus Hydrostatic traction control (HTC) #21
Mountaineer, Dealer is correct. Any 5610 that has the required cab & mainframe harness, axle shafts to accept the added speed sensor came with HTC as standard equipment, it was/is option for 5600. APFB12000 is 5610 starting serial number with all correct parts, HTC installed.
   / Limited slip differential versus Hydrostatic traction control (HTC) #23
Man, is there ever a lot of confusion over this stuff. Different dealers are saying completely different things.
What is your comment on "differential only working in 2 wheel steer mode"???
I just tested ours in 2 wheel steer, by approaching this steep rise at the edge of the driveway at an angle, so only the left front wheel goes up it.
As soon as the right front lost traction, the left rear would spin also, so the limited slip is not working on our 5610 F.
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
1951 (A57192)
1951 (A57192)
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
2013 Ford F450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A55852)
2013 Ford F450 4x4...
