Like the rk37. Are there any 3rd function options?
   / Like the rk37. Are there any 3rd function options? #31
I believe you are correct. Diverter is not a bad thing, just operates a little differently.
   / Like the rk37. Are there any 3rd function options? #32
It’s my understanding from reading different posts a lot of people prefer the diverter. Being able to control the speed of opening and closing the grapple is not a bad thing. I have been using a rear remote so I can’t say what’s best but I see no problem with either
   / Like the rk37. Are there any 3rd function options? #33
Mine is as described above. A single button. Although I don’t have a grapple yet, when I press the button it takes the place of the curl function which I image would open and close the grapple with button depressed and moving joystick left and right. Raise and lower still works as expected.
   / Like the rk37. Are there any 3rd function options? #34
I'm pretty sure it's actually only a button not a button/joystick. Which would mean you can EITHER curl or close/open grapple, not both at the same time. Not sure exactly if that qualifies as a diverter or not, but I'm thinking it is only a press in/release button on the joystick.
Yes, I misread what he said. Guess I have to slow down and read. I completely missed the line where he says push the button and move the joystick right to open the grapple.
Yes this is a diverter and is preferred by most because you can feather the opening and closing of the grapple lid. You can go fast or slow. With a true third function valve it is either full blast or off.
   / Like the rk37. Are there any 3rd function options? #35
Yeah, after doing a little research on what exactly a diverter is and isn't, I'm actually glad to have that option. I think for what I would need/use it for having control over how fast or slow it closes would be much better than being able to do both at the same time.
2021 KUBOTA SSV75 SKID STEER (A52707)
2021 KUBOTA SSV75...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
2006 JLG 2030ES 20ft Electric Scissor Lift (A55851)
2006 JLG 2030ES...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2019 Dodge Grand Caravan SXT Van (A55853)
2019 Dodge Grand...
2025 Swict 66in Bucket Skid Steer Attachment (A55851)
2025 Swict 66in...
