Like the rk37. Are there any 3rd function options?
   / Like the rk37. Are there any 3rd function options? #12
I stopped by our local RK and they told me it was a diverter. That you could not use the raise/lower function while using it. I looked at one connected to an RK 55. I didnt see it work but was just a single button on bottom of the joystick. I would assume would have to have 2 switches/buttons to operate independently.
Can you please tell he what RK location told you it was a diverter? May have a training opportunity.
Bluefield WV. He said that you lose the raise lower function of the loader while using the 3rd Function and that they do not install it there that he would order me a tractor with it installed that would take 7-10 Business days. Said could not add it to a Tractor on the lot. And quoted it at $839 I believe. Somewhere in the low $800s. Is this not correct? If not how does the 3rd function work?
   / Like the rk37. Are there any 3rd function options? #14
I was told for the RK55 the price would be: for the 3rd function valve kit, $749. And installation of the valve kit is $225. I would think it would be the same kit and same price for the RK37 as well.
   / Like the rk37. Are there any 3rd function options? #15
Also, as far as adding it to a tractor on the lot, their service dept should absolutely be able to add it. What if you had already purchased your tractor and wanted to add it later? You would order the kit and when they got it from their service center you would bring in your tractor and they would install it. So no different from them ordering a kit and installing it on one on the lot. Same should be true if adding a backhoe later or adding a 3rd function thumb for your backhoe later. Correct me if I'm wrong, but that just wouldn't make any sense if you couldn't add things later.
I agree. I was quoted online through someone with rk that exact same price that you were given. Don’t know why local salesman had different numbers. And I still don’t know if it’s a diverter or what.
   / Like the rk37. Are there any 3rd function options? #17
See post #11 :thumbsup: Not a diverter, full function.
   / Like the rk37. Are there any 3rd function options? #18
Thank you for your reply. You received incorrect info. Please send me an email; rktractorguy@ruralking.com with your contact info.
We can install a 3rd function kit on an RK37 or RK55 tractor anytime. $749 plus $225 labor.
Thank you for clarifying. I keep drooling over the cab RK37. I need a tractor to pull double duty to mow part of a steep 3-4 acres. But also plow snow in the winter. Your brand is hands down winner to plow snow. In my budget just maybe too big to mow with. Decisions decisions.
   / Like the rk37. Are there any 3rd function options? #20
You can see the grapple in action at this link. It is to a video on Outdoors With the Morgans YouTube channel. If you want to see RK Tractors being used in a range of applications, subscribe and hit the bell to get notifications every time a new vid is posted.
#212 After work Chores! Firewood and Mowing - YouTube
2014 Dodge Charger Sedan (A55853)
2014 Dodge Charger...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
