Lights
/ Lights #1
Brady D
Southern Middle Tennessee
Ford 1910, Case farmall 95, John Deere 317g
The lights on my Ford 1910 will go dim and then bright when the engine strains or if your starting to drive is there anyway to fix that
/ Lights #3
Are lights bright without engine running? I would test the battery after tractor has sat overnight or longer. If it has less than 12.6 Volts take it to an auto part store for load testing. If battery check's out ok,make sure belt isn't worn and/or slipping.
/ Lights
It has a brand new belt I’ll try to test the voltage
/ Lights #5
Clean the battery terminals and the surfaces on the connectors. Tighten securely. Follow ground wire to frame. Clean and tighten.
2007 CM TRAILER 18' T/A ENCLOSED TRAILER (A65643)
2007 CM TRAILER...
1994 Aeromax Semi Truck (A66285)
1994 Aeromax Semi...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
2012 Peterbilt 587 (A64127)
2012 Peterbilt 587...
2015 John Deere 6125R (A64126)
2015 John Deere...
Kinze KM3000 Monitor (A65640)
Kinze KM3000...
