Lights
/ Lights #1
Brady D
Southern Middle Tennessee
Ford 1910, Case farmall 95, John Deere 317g
The lights on my Ford 1910 will go dim and then bright when the engine strains or if your starting to drive is there anyway to fix that
/ Lights #3
Are lights bright without engine running? I would test the battery after tractor has sat overnight or longer. If it has less than 12.6 Volts take it to an auto part store for load testing. If battery check's out ok,make sure belt isn't worn and/or slipping.
/ Lights
It has a brand new belt I’ll try to test the voltage
/ Lights #5
Clean the battery terminals and the surfaces on the connectors. Tighten securely. Follow ground wire to frame. Clean and tighten.
Arrow Quip 7500LMR Cattle Chute w/ Head Holder (A64047)
Arrow Quip 7500LMR...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
more info coming soon (A61569)
more info coming...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
