Lights flickering on lawn tractor
/ Lights flickering on lawn tractor #1
Matthewf13
The lights on my Craftsman lawn tractor flicker when I go over bumps (as if a wire is loose). BOTH do it.
Any ideas on fixing this problem would be appreciated.
/ Lights flickering on lawn tractor #2
More than likely oxidation on connectors in the lamp circuit or the wire harness. You would have to unplug them and look inside the connectors to see if they are corroded. Some times you can get contact cleaner at the autoparts store or Radio Shack. If you get the contacts cleaned up then put some dielectric grease in the connectors before you put them back together. Also look at the ground connections from the battery to frame. If it starts ok you battery connections may be good. It doesn't hurt to take of the battery clamps and clean those up.
/ Lights flickering on lawn tractor #3
Also check to see where the lights are grounded. I have seen a couple of models that used the hood pivot bolts as the ground point.(Not sure if this was factory or home owner) After opening the hood a few times the connections become loose.
/ Lights flickering on lawn tractor #4
ditto that.. the lamps on my murray ground to the hood, which pivots. ie.. imperfect ground.
soundguy
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2006 FRAC TANK 500BBL WHEELED (A60736)
2006 FRAC TANK...
Sweeper attachment (A61567)
Sweeper attachment...
INGERSOLL RAND G25 GENERATOR (A60736)
INGERSOLL RAND G25...
2019 Chevrolet Tahoe SUV (A60352)
2019 Chevrolet...
2023 FREIGHTLINER M2 4X2 24FT NON CDL SLEEPER BOX TRUCK (A59906)
2023 FREIGHTLINER...
