Lighting for the pole barn
   / Lighting for the pole barn #11
While cheaper than they use to be, 50w-100w LEDs are not 'cheap'.
   / Lighting for the pole barn #12
Its funny cause I just built a 24x30 pole barn with 2 garage doors 3 windows and a 10x30 Patio. I need lights and other Power sources too.
   / Lighting for the pole barn #13
My pole barn addition is 18 x 32 (same sq. ft as your 24x24). I installed 8 - 4' T8 cold start fixtures. Each fixture has 2 T8 tubes. They provide plenty of light and don't use much power. I put 4 fixtures per light switch.
   / Lighting for the pole barn #14
This is what I been putting in my barn as well, Menards has some on sale right now too, so price is good and power vs light is good. Mine light down to -20 rather OK but take a few min to come up to full light when that cold. but I dont move well then either ;)
Mark
   / Lighting for the pole barn #15
+1 on the T8s, I have the same setup. Plus 7 windows - I like the place nice n bright.
   / Lighting for the pole barn #16
LED's are a LOT cheaper than they used to be.
You have energy savings for as long as the barn is there.
You do not have climb a ladder to change bulbs/tubes for forty years......think of the reduced chance of accidents.
http://www.tractorbynet.com/forums/projects/282349-led-lighting-pole-barn.html
They are still very expensive in comparison. As for the 40 year lifespan, all I can say is LOL. Most don't seem to last very long.
For occasional use, like an hour a day or less, energy savings are insignificant compared to cost. In our barns, the lights are probably used less than an hour per month. There is no way any higher initial cost will save money.
Fluorescent lights work well in warm temps, but are low output and slow to start (if at all) in cold weather. I have them in my shop but I'm not going to be out there if it's 20 degrees.
For limited use (hours per day), the good old incandescent bulb is cheap and effective, and works just fine in cold weather.
   / Lighting for the pole barn #17
Oh, another problem with flourescent bulbs in rural areas is disposal of the old bulbs. I have several dozen here that I can't get rid of. No, Lowe's doesn't accept them. The only thing I have found is a one day a year haz waste disposal center, 30 miles away. That sure saves a lot of energy....NOT.
   / Lighting for the pole barn #18
I put four two-tube, 8-foot T8 fluorescent fixtures in my 24 x 24 garage and it's sufficient for storage and basic maintenance. Having walls and a ceiling covered in drywall painted white would help I'm sure but even without it's pretty light in there. It all depends on the kind of work you'll be doing. If you're doing body work or something along those lines I would step it up to guarantee no dark areas. I've read that the light reflectors help but I do not have those on my fixtures so I couldn't comment on that. The nice thing about the T8s is that they don't use as much energy or run as hot as the old cold weather ballasts, which were also much noisier. I'd like to hear what the experts have to say about spacing them out. Is there some sort of formula when laying out the fixtures?
   / Lighting for the pole barn #19
I would be inclined to spring for something like this
Tasco 100 ft. 12/3 SJTW 10-Light Plastic Cage Light String - Yellow
They cost $150 at Home Depot but, they take standard 150 watt light bulbs and come ready to hang and just plug in. To me, the ease of use and safe operation would be worth the expense. Especially since anything you "put together" may cost just as much.
If you are working from a generator, I would go with the incandescent since they can take power variations and still work.
   / Lighting for the pole barn #20
My shop is 24x30 with 12 foot walls and I have four sets of 8ft long fluorescent lights in there that work great.
Eddie
2021 Isuzu NRR Heil 9Yd Mini Rear Loader Garbage Truck (A50323)
2021 Isuzu NRR...
2007 Jeep Liberty (A50515)
2007 Jeep Liberty...
Stage Line Trailer (A50322)
Stage Line Trailer...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
Ih 1066 Tractor (A50514)
Ih 1066 Tractor...
TEST BID LOT (A50775)
