Light on helmet
/ Light on helmet #1
escavader
western maine
bx-23 ,
I always see better with a bright light where i weld . That being said anyone ever thought of adding a light to your helmet? Such as a small rerangular led .am i foolish?
/ Light on helmet #2
I don't see why not. If your neck can handle the extra weight. My neck can't! Too many years of wearing a hard hat welding hood.:mad:
/ Light on helmet #3
I once saw a light made to go on a welding helmet. It had a mercury switch to turn it on when it was in position, and off when you raised it up. It was powered by your welder via two small battery clamps. When you struck an arc, the light would go out as the welder's open circuit voltage dropped to welding arc voltage.
I think a modern light could be made to work even better.
/ Light on helmet #4
I have never tried one of these, but it seems like a cool idea. Might pick one up, or rig something similar.
McMaster-Carr
A light on the torch seems even better than the helmet.
/ Light on helmet #5
If I don't have to pay for electricity. I would vote for the Halogen light either on the table or on the telescoping stand. Very bright. I do understand the pin point light of the helmet light. However, When the Lens goes dark under the arc, Lights don't matter.
/ Light on helmet #6
Sounds like a great idea, I like it.:thumbsup:
/ Light on helmet #7
McMaster-Carr
This looks like a good idea, but when welding with flux core wire, wouldn't the lens get dirty reducing the light's effectiveness?
/ Light on helmet #8
I'd like bright lights on my helmet. I often end up welding at the end of the day. Even when the lens goes dark it helps to see around the weld area. And when the lens is not dark it helps to see around the weld area too. Note if your habit is to lift the helmet up your light goes away.
Plus if you look at your spectators (with bright lights) and forcefully ask them if they like your welds they quickly reply YES.
/ Light on helmet #9
I wouldn't put a light on the MIG torch that close to the weld spatter and heat. I don't think it would be effective for very long due to smoke/weld spatter on the lens.
I think the best option is a quartz halogen type light mounted on an adjustable stand that you can focus on the project. They are cheap to buy but a little bit of an energy hog but then so is the welding machine. At least these wont add weight to your helmet and wont be affected by the smoke and fire from your welding.
/ Light on helmet #10
I like the idea too but I think you need a lot of light to make it really worth while. I do set up my portable halogen lights on a stand but it would be cool to have high output concentrated light on the subject.
/ Light on helmet #11
A light on any torch would inevitably get in the way and cause "bobbles" in your weld beads.
I'm tired of those halogen lights. They're dangerous fire-starters, they melt stuff, the bulbs burn out when they fall over, and they spark in the ext cord ends, wearing out your cords.
With all this discussion,,,,,, I just ordered this one. Will see how it works out. It needs a storage cubby or bag for the cords.
452039d1451463873-light-helmet-51ed6pvzeml-jpg
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
2022 EZ-GO ELITE...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2014 Nissan Quest Van (A61574)
2014 Nissan Quest...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
