Lifting Hook Placement FEL & Hoe
/ Lifting Hook Placement FEL & Hoe #1
Anonymous Poster
Epic Contributor
Need to get some ideals of where to place lifting hooks on my B7500 FEL and also how to reinforce it for the top center lifting hook. I plan to put 1 on each side and also 1 in the top center along with a reciever plate for hitches. I will need to raise the hitch receiver above the lip on the bucket (about 1 3/4"). Any ideals or photos would be great. I plan on welding 1 in the rear center of my backhoe bucket. Thanks
/ Lifting Hook Placement FEL & Hoe #2
Dont' know if you can do this on your bucket but I just used a piece of heavy 3 inch angle iron that I cut some slits in that the chain would slip into. Bolted it across the whole top so it served three purposes 1. removable if I ever needed to 2. reinforced the whole top of the bucket and distributed the force better than hooks do, 3. cheaper than hooks, and didn't have to weld (Back then I couldn't, now I can and would still probably do it this way. See pic
/ Lifting Hook Placement FEL & Hoe #3
Dont' know if you can do this on your bucket but I just used a piece of heavy 3 inch angle iron that I cut some slits in that the chain would slip into. Bolted it across the whole top so it served three purposes 1. removable if I ever needed to 2. reinforced the whole top of the bucket and distributed the force better than hooks do, 3. cheaper than hooks, and didn't have to weld (Back then I couldn't weld, now I can and would still probably do it this way). Sorry can't attach a pic - when I took it it was 317 kb and there's a 100KB upload restriction now /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif Search some old threads on bucket hooks and you may be able to find an old one.
I would love to see that pic, but I get an error message when I try to download it - could you upload it again?
Thanks!
/ Lifting Hook Placement FEL & Hoe #5
old post See if this link to an old post from 6/4/02 will work - has a closeup pic of my setup
/ Lifting Hook Placement FEL & Hoe #6
I saw that approach here in a post last year, and did a similar angle installation.............chim
/ Lifting Hook Placement FEL & Hoe #7
Nice job Chim! You know the old saying "Imitation is the sincerest form of flattery!!" (Not that I came up with this myself - I saw something similar and just applied it to my situation) /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
13ft. Disc (A65640)
13ft. Disc (A65640)
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
53ft Dry Van Trailer (A65563)
53ft Dry Van...
2019 K&K Trailer, VIN # 1K9PE2027KA175461 (A65563)
2019 K&K Trailer...
