lift problem
/ lift problem #1
jrboatwr
I have a 165 massey ferguson ,the lift will not go down.The draft control is springing all the way up. I would appreciate any repair suggestions.
/ lift problem #3
Hello & WELCOME to TBN!
I moved your thread to the Massey Ferguson Owning/Operating Forum. :)
/ lift problem #4
Is the tractor new to you? If not, has it worked since you've owned the tractor and what were you doing with it when it stopped working.
/ lift problem
I am actually a machanic working on the tractor for a local farmer.She was box blading around poultry house when see lifted it up and would not go down.I work on suiunityeveral different tractors thru out the community but this is a problem I have not had to deal with yet.
/ lift problem #6
I'm on the road but you're saying the draft control lever springs up or the lift lever. I constantly am bumping my draft lever, which will make the lift control lever useless. Make sure the draft lever is all the way up and try the lift lever.
/ lift problem
Thanks for the info,I found the problem.The control valve on pump is stuck.I am in process of making parts list now to order.If you have a breakdown on the hydraulic system for a 165MF that you could send me,Iwould appreciate it.
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A67148)
2013 CORPUS 40FT...
2018 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2018 Kenworth T800...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
Craftsman 16in Variable Speed Scroll Saw (A64553)
Craftsman 16in...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
