lift problem
/ lift problem #1
jrboatwr
I have a 165 massey ferguson ,the lift will not go down.The draft control is springing all the way up. I would appreciate any repair suggestions.
/ lift problem #3
Hello & WELCOME to TBN!
I moved your thread to the Massey Ferguson Owning/Operating Forum. :)
/ lift problem #4
Is the tractor new to you? If not, has it worked since you've owned the tractor and what were you doing with it when it stopped working.
/ lift problem
I am actually a machanic working on the tractor for a local farmer.She was box blading around poultry house when see lifted it up and would not go down.I work on suiunityeveral different tractors thru out the community but this is a problem I have not had to deal with yet.
/ lift problem #6
I'm on the road but you're saying the draft control lever springs up or the lift lever. I constantly am bumping my draft lever, which will make the lift control lever useless. Make sure the draft lever is all the way up and try the lift lever.
/ lift problem
Thanks for the info,I found the problem.The control valve on pump is stuck.I am in process of making parts list now to order.If you have a breakdown on the hydraulic system for a 165MF that you could send me,Iwould appreciate it.
2002 EZGO Electric Cart (A64557)
2002 EZGO Electric...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2014 Ford F-550 4x4 Versalift SST40EIH-01 40ft. Insulated Bucket Truck (A64556)
2014 Ford F-550...
2022 EZ-GO ELITE...
2019 KUBOTA SVL75-2 SKID STEER (A65053)
2019 KUBOTA...
