not2old
Veteran Member
- Joined
- Oct 16, 2010
- Messages
- 1,526
- Location
- Scotch Creek, British Columbia
- Tractor
- 2010 Massey GC2610TLB
My GC2610 has a much lower capacity but when I encounter this problem, I let the logs swing a bit and the loader will rise a bit higher. I also lift with the bucket in the dump position and then use the curl which has higher capacity. I've never lifted anything heavier than 900 lbs.I can lift a ton on pallet forks pretty easy. (bridgeport series 1 9x49 with 8" riser on a oak skid). Estimating 2200#. But only high enough to transport.
Not sure if I could lift it off of something trailer height. Loaders have the most lift capacity at ground level. And the least at max height.
In the case of the MX, the LA844 loader is rated at the 2400 to max height, but half height (59") it can lift 3030# and at ground level its 4180# at the pins. And more realistic....19.7" forward of the pins, its 1840# to max height, 2450# to 59" and ground level its 3260#
Noticeable in the real world too. I load and move alot of logs on the dump trailer. Load them with the grapple. Sometimes I can grapple a log, raise it ~1-2' to get to the trailer, then go to raise it to load and can only get 3' or 4' before it just runs outta muster and have to cut the log smaller. So maybe it was a 3000# log, and the 3260# capacity at ground level was enough to lift and move it. But to get to 59" high to clear dump trailer the log needed cut down to 2450# per spec.
