Lift kit for tractor
   / Lift kit for tractor #11
Cut a ditch to drive the trailer down into.
   / Lift kit for tractor #12
My perception is the OP finds himself loading this trailer in various locations. Real PITA to have to build a ramp or dig a ditch. Then add that the customer might not appreciate that in their driveway. :)
I think it's back to the trailer dealer or go visit the tractor dealer. :(
   / Lift kit for tractor #13
What about smaller tires on the trailer? Or somehow flipping the axles on the trailer? I have read about flipping travel trailer axles to gain height. Can you do the opposite?
   / Lift kit for tractor #15
A 4 in 1 bucket might work. You can shorten the height required to dump by about 18 inches. Changing tire size on the tractor can’t be done( unless you change all 4 to the proper ratio ) even then it’s not practical because the loader won’t reach the ground and you’ve raised the center of gravity. Changing the trailer tires to 10 inches smaller isn’t practical. Building a ramp that you haul around might work assuming you don’t use it very much.
   / Lift kit for tractor #16
Ditto on this. How are the axles run under the trailer. Can they be flipped without the tires contacting the dump bed?
   / Lift kit for tractor #17
Oops. Kinda like buying a new truck and getting it home only to find that it doesnt fit in in garage! Think you need another new trailer. Your boss will understand. :shocked:
   / Lift kit for tractor #18
He just had that one custom built. Doubt the trailer dealer will take it back. I still say he needs to upgrade from his LS3033H. Should still get a decent price selling it.
   / Lift kit for tractor #19
What’s the total height of the trailer? The lift to pin height of my loader is 4 inches higher than yours the sideboards of my truck are higher than most dump trailers that I’ve seen.
   / Lift kit for tractor #20
I'd second the suggestion on a 4-in-1 bucket. You can dump loose materials from the bottom of the bucket without having to dump/curl it... just open it. Of course, that means you'll have to find and purchase a 4-in-1 bucket and add hydraulics to open and close it.
But a 4-in-1 bucket is also very useful as a grapple for cleaning up stuff.
SHOPBUILT T/A TRAILER (A52708)
SHOPBUILT T/A...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
CASE MXM 190 (A58214)
3079 (A56857)
3079 (A56857)
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
