lift arms won't stay put!
   / lift arms won't stay put! #1
oldboyscout
ne PA
Kubota B2620
Lately my B2620 has developed an issue with the stay chains on my lower lift arms. They loosen drastically every pass I make down the driveway with the backblade. They used to stay tight quite a while. I can't find anything that has changed much to cause it. Any Ideas how to keep them tight?
thanks
   / lift arms won't stay put! #2
Sounds like the threads have worn in. Are there lock nuts on them? If so need to replace them. If not add them.
   / lift arms won't stay put! #3
Are the pins still in place that keep the turnbuckles from turning?
I don't think the threads are worn. I guess I should add lock nuts.
I can't see anywhere that a pin would keep them from turning (other than the end to keep from coming off completely)
   / lift arms won't stay put! #5
If you are missing them, and it seems you may be, two of these little jewels should solve your problem. They do keep the turnbuckles from turning. That is their purpose.
Kubota PIN, SPLIT Part #05515-51200
This is assuming you have the stock check chains like mine.
   / lift arms won't stay put! #6
that looks like it'll do the trick. Can't recall ever having them on any of my tractors.
thanks much
New Holland LX885 Skidsteer (A51573)
New Holland LX885...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2018 Komatsu WA380-8 Articulated Wheel Loader (A51691)
2018 Komatsu...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53472)
2017 Yale GLC050VX...
