lift arms won't stay put!
   / lift arms won't stay put! #1
oldboyscout
ne PA
Kubota B2620
Lately my B2620 has developed an issue with the stay chains on my lower lift arms. They loosen drastically every pass I make down the driveway with the backblade. They used to stay tight quite a while. I can't find anything that has changed much to cause it. Any Ideas how to keep them tight?
thanks
   / lift arms won't stay put! #2
Sounds like the threads have worn in. Are there lock nuts on them? If so need to replace them. If not add them.
   / lift arms won't stay put! #3
Are the pins still in place that keep the turnbuckles from turning?
I don't think the threads are worn. I guess I should add lock nuts.
I can't see anywhere that a pin would keep them from turning (other than the end to keep from coming off completely)
   / lift arms won't stay put! #5
If you are missing them, and it seems you may be, two of these little jewels should solve your problem. They do keep the turnbuckles from turning. That is their purpose.
Kubota PIN, SPLIT Part #05515-51200
This is assuming you have the stock check chains like mine.
   / lift arms won't stay put! #6
that looks like it'll do the trick. Can't recall ever having them on any of my tractors.
thanks much
20" Sea Container (A47384)
20" Sea Container...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
2018 TAKEUCHI TL12V-2 SKID STEER (A51246)
2018 TAKEUCHI...
2003 CATERPILLAR 277 SKID STEER (A51246)
2003 CATERPILLAR...
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
2012 John Deere 7230R (A53472)
2012 John Deere...
