lift arm?
/ lift arm? #1
john haylow
bracebridge on
kubota
I have a 1993 Kubota that has the turn buckle lower lift arm adjustment, and it is a real fight to get some of my equipment hooked up , especially my Rino brush cutter. I'm thinking of getting something that would be less frustrating. Any thoughts.
Thanks,
John
/ lift arm? #2
What model/size Kubota do you have?
How long have you been tractor-ing?
Are you connecting LEFT 3-Pt. "eye" to Rhino draw pin first, then using right, adjustable lift arm to adjust height of RIGHT 3-Pt. "eye" second?
The reverse connection order is usually difficult.
Draw pins lubricated? I use spray graphite, which polishes draw pins over time.
Often a minor turning in/out of the 3-Pt. Top Link will line up the right 3-Pt. "eye" to the right draw pin.
How about pictures?
/ lift arm? #5
So what you describe as a turnbuckle, I might describe as a lifting rod, similar in construction to your Top Link but shorter? Did you back off lifting rod lock-nut?
Does the lifting rod adjust easily?
What type of stabilizers/check chains support the two 3-Pt. Lower Lift Arms?
Can you slacken stabilizers after backing up tractor to Rhino SQUARE, so the Lower Lift Arm eyes can be swung over to draw pins?
Do my suggestions seem to address the problem?
How long have you had the tractor?
What step of mounting the Rhino is giving trouble first?
/ lift arm? #7
Tractordata indicates three years of production for L3650: 1990-1993.
/ lift arm? #8
I used to have a L3650 (for 20 years) - and it was not a Grand L model (EDIT: Oops, saw jeff edited his posts). One of the best thing I ever did was toss on a set of Pat's Easy Change quick hitch.
Given the problems the tractor/attachments are giving you, Pat's is an excellent solution.
Stabilworks lower arm stabilizers run about $150. They are most effective for BX tractors whose lower lift arms collapse inward. UGH! They have made changing implements on my BX a dream (the BX also has a set of Pat's)
2014 FORD E-350 11 PASSENGER VAN (A65643)
2014 FORD E-350 11...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
250 Gallon John Deere Sprayer (A65579)
250 Gallon John...
