lift arm pins
   / lift arm pins #1
tonyw
NC
YM1401d
Anyone know a good source for replacement lift arm pins? One of mine came loose and fell off while I was tilling...I'd had trouble before with the nut coming loose, and should've had sense enough to put some Locktite on it... /forums/images/graemlins/blush.gif
thanks!
   / lift arm pins #2
If you are talking about the upper one.(part of the tractor), probably a dealer. For the lower one, (part of the implement), any tractor parts/supplies place such as TSC.
   / lift arm pins
Thanks, Norm! Sorry, I meant to mention it is the upper lift arm pin on a 1401d.
Thanks!
   / lift arm pins #4
Tony,
The 1401 did not have lift pins originally. They were probably installed as part of the 3pt conversion. They are likely either category 0 (5/8") or category 1 (7/8") 3pt lift pins. They are available at any tractor store. Just take the old one with you to get the right size.
   / lift arm pins
Thanks, Greg! It's cat. 1...just didn't know if those things were readily available...and might have to order it. I guess I'll try Tractor Supply.
Thanks again!
   / lift arm pins #7
never hurts to have an extra pin or two around,will save a trip out when you realy don't feel like it,and you always have trouble ,when you want to use tractor. murphey's law
lippy
   / lift arm pins #8
TSC does carry the upper pins for most tractors I put a new set on mine after i noticed one was bent assuming it's cat 1
   / lift arm pins #9
Tony, the upper arm pin on your YM1401 should be 3/4" with 12mm threads, the pin should be 3 9/16" long. I have them in stock if you can't find one.
Danny
Parker Equipment Co
   / lift arm pins
Thanks to everyone for your help! Danny, I'll be in touch....
Sorry it's taken so long to reply...we just had a new arrival on Thursday, a baby girl, so my mind is elsewhere! /forums/images/graemlins/grin.gif
Tony
   / lift arm pins #11
Yep, Tony, that'll definitely take your mind elsewhere for awhile. /forums/images/graemlins/wink.gif Congratulations! Hope momma, poppa, and young'un are all doing well.
   / lift arm pins
Thank you, Bird! Everyone is fine....I'm even getting a few hours of sleep every few days! /forums/images/graemlins/grin.gif
Who knows when I'll get back on my tractor--it's amazing how a baby can keep your attention even when they're sleeping. My wife accuses me of already being wrapped around this little girl's finger!
thanks again for the well wishes!
Tony
2422 (A60432)
2422 (A60432)
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61306)
2017 Yale GLC050VX...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
207277 (A52708)
207277 (A52708)
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
