Lienbach Plow
/ Lienbach Plow #1
Devildog
Platinum Member
Luray, VA
Kubota B2630
I just puchased a new Linebach 1-12 plow. I purchased this plow after the recommendation from my local implement Co with my type of terrian. After looking it over good I realized it was built a little heavier that I thought for a 1-12 plow and after using it plowing a couple of gardens it worked great.
Cost was $289.00
Here is a pic.
___________________________________
Take care all, Jim
/ Lienbach Plow #4
Re: Leinbach Plow
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=implement&Number=71869&page=&view=&sb=&o=&vc=1>More Leinbach Discussion and Rake picture…</A>
Jim,
I think Leinbach is another sleeper of a company similar to KingKutter… very good quality product for the dollar… in other words you can get some decent implements for an excellent price… /w3tcompact/icons/smile.gif
/ Lienbach Plow #5
Re: Leinbach Plow
Unlike many of the posters here, I've never had a good opinion of King Kutter. It's built to be low cost. I have a Leinbach disc that has tube steel for the frame. KK uses angles. Leinback's stuff is built heavier than equivalent KK
equipment.
KK is fine for light duty but the stacks of KK equipment rusting before it got sold outside of the local, now defunct, Quality Farm & Family never impressed me.
/ Lienbach Plow #6
Re: Leinbach Plow
<font color=blue>...Quality Farm & Family ...</font color=blue>
I've seen that problem there with the Howse implements real bad... also the angle iron is used alot on the leader model "Worksaver" implements also painted yellow at Quality... sometimes passed off as "KingKutter"...
All in all, I think both KingKutter and Leinbach have lots of value for the dollar... there are many other implement companies out there that charge much more... and the consumer buys on "name" and ends up getting much less...
/ Lienbach Plow #7
A couple of questions for you, having no plow experience, yet, and about to embark upon purchasing a plow for similar uses:
1. Could you get 12" deep on the first pass? What kind of soil do you have, that made this unit the best choice?
2. What HP tractor is the plow attached to---I'm assuming from the "HST" on the fender, it's in the 40-range?
Thanks,
Raphael
/ Lienbach Plow #8
I can see the plow is flat to the 'ground' in this picture, but to be adjusted correctly for plowing, seems to me it should be flat to the ground only when the left rear wheel is off the ground the same distance as the depth of the intended furrow (plow 6" deep, then 6" off the ground).
If plowing as it is adjusted, the bottom of the furrow will not be level (flat) right to left, and you will just be dragging the point of the plow under the dirt. The front to back leveling is done with the top arm adjustment. The right to left leveling is done with the height adjuster on the right 3pt lift arm (at least for this plow).
/ Lienbach Plow #9
Don't mean to answer for Jim, but according to his sig line, it's a B7500 HST which is 21 gross HP and 16 pto HP.
Hoss
/ Lienbach Plow #10
Re: Leinbach Plow
Darren,
<font color=blue>a Leinbach disc that has tube steel for the frame. KK uses angles.</font color=blue>
Like several manufacturers, KK offers both. Their angle frame disc:
runs to a maximum weight of 560 lbs for a 6'5" disc with 20 18" blades. Their box frame disc:
for the same size (6 1/2 feet) with 20 18" blades weighs in at 790 lbs. They also offer the box frame disc in sizes up to 7 1/2 feet with 24 20" blades weighing in at 880 lbs. Figures come from <A target="_blank" HREF=http://www.kingkutter.com/index.asp>King Kutter's</A> web site.
Hoss
/ Lienbach Plow #11
Re: Leinbach Plow
Thanks Randy...
Yes KK has a couple flavors of implements... and yes "if" Quality even stocked the disc... it would have been the angle iron cheaper flavor and not the heavy duty box frame...
And comparing apples against apples with the Leinbach vs. KK boxframe disc... it's about the same, maybe Leinbach has a better A-frame, which is one of the weaker points with the KK line... but normally using an under 35hp tractor it tends to be a moot issue...
/ Lienbach Plow
Raphael,
1. 12' deep on the first pass, Not with my terrain its is very rocky soil and not enough tractor to go that deep, but I was always taught you didnt want to turn over no more than 6". I actually have more tracotor than I need but I keep our road open when we have snow(not much this year) And I plow gardens for people.
2. As Randy said its 21HP and the HST is for hydrostatic transmission(auto)
beenthere,
I had the plow set level for pic purposes. But it didnt take much angle to get it to cut in, The only problem was rocks rolling it back up/w3tcompact/icons/smile.gif
The reason I ended up with the Liebach
1. the price was in my range, He can get any plow you want but this is the size he recommended.
2. It looked pretty sturdy.
3. And I love going to look at equipment/w3tcompact/icons/smile.gif
__________________________________________
Take care all, Jim
/ Lienbach Plow #13
Re: Leinbach Plow
I stand corrected Hoss. I run the Leinbach disc behind a 60 hp pto tractor (Ford 5600) and it's never flinched. I looked at the KK brochures at Quality and never saw the tube framed disc. Of course Quality may have never carried them.
That's the great thing about this forum. You can always learn something.
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
2022 EZ-GO ELITE...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2022 EZ-GO ELITE...
2020 KENWORTH T880 (A65643)
2020 KENWORTH T880...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
