Leveling Wash-Board type ground
/ Leveling Wash-Board type ground #1
DGB
Boonsboro, Maryland
Deere 4110 HST
I have about 1/2A of ground that for lack of a better term is like a wash-board from water run off. The area is not very steep and the ruts not too deep, but they can beat you up when trying to cut. I would like to level out and re-seed to get better quality yard in this area. Not good enough with FEL yet to do anything decent. I am thinking to purchase a rear blade or box blade. Would it be better to work accross the ruts or up and down? Other option would be to rent a rear tiller and just smooth out with landscape rake. Any ideas and/or input would be appreciated.
DGB
/ Leveling Wash-Board type ground #2
I had a similar problem this spring during construction on our house. I elected to use a box blade and found that going with the ruts gave the best results. The box cut the top off the high areas and dropped it into the ruts as it went along. All told, it did a bang up job and didn't take long at all.
/ Leveling Wash-Board type ground #3
Forgot to mention it, but since you don't have a BB, go ahead and get one. Most valuable and versatile tool you will own, even if you don't use it for this project.
/ Leveling Wash-Board type ground #4
<font color="blue"> Forgot to mention it, but since you don't have a BB, go ahead and get one. </font>
Good advice!
And it does not have to be an expensive one to give great results. I have a KingKutter 60" that I paid under $300 for and I just love it.
Not as heavy as some, but a few concrete blocks on it solves that problem.
A great implement. Ranks right up there with the tooth bar for the loader bucket... /forums/images/graemlins/smile.gif
/ Leveling Wash-Board type ground #5
Skitch's method will work if your soil is soft enough. If it's hard, you can go backwards across the ruts with the boxblade and smooth out a lot quicker than going forward. When you go forward, you wheels hit the ruts and bounce the blade. If you go in reverse, the blade cuts the rough ground before your wheels get to it. It takes a little practice, but I do a lot of cutting/grading in reverse with my boxblade.
I'd give Skitch's method a try first and save the reverse method for the tough spots. /forums/images/graemlins/cool.gif
/ Leveling Wash-Board type ground #6
The BB is probably your best bet, since to rent a tiller will cost you a good fraction of the cost of a BB and then you'll have the implement /forums/images/graemlins/grin.gif.
I used a tiller (rented) on my yard, and it did an excellent job, but then I wound up borrowing a BB to finish level it. You might not need to do that, but if you don't you want to make sure you get something growing in it before erosion puts you back to square one.
/ Leveling Wash-Board type ground #7
Have you thought of contouring the upper part of the area to conrol or direct water runoff to a specific area?
Will you be reseeding the entire area or just the washboard area as this may make a change in the choice of impliments used.
Egon
Good advice. Think I will go for the BB. Sounds like a good thing to have anyway. Once done I will plant a mix of annual rye for a quick growth and fescues for the long run. Hopefully water runoff will be less then before as the area above now has a well established lawn.
Thanks,
DGB
/ Leveling Wash-Board type ground #9
DGB,
You'll love having a box blade. I have that on my tractor more than about anything besides my mower in the summer and about all the time during winter for ballast. It's heavy and still compact enough to reduce the dragon tail effect when I turn.
I have a 5' model made by Midwest. The quality of the welds along with the fit and finish quality are all excellent. They're about the same money as a King Kutter but if you put them side by side the choice is obvious.
Good luck with whatever you decide. I hope this helps. /forums/images/graemlins/smile.gif
2013 Crane Carrier Co. Low Entry T/A 25Yd Rear Loader Garbage Truck (A61573)
2013 Crane Carrier...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
