Leveling ground with disc
/ Leveling ground with disc #1
LabLuvR
SC
Kubota MX5400
I had a fellow come over with his huge hydraulic disc to do my fields while I over came knee surgery. The fields look great but I see some places where he left me a few places with a ridge and valleys off to the side. I just need to knock the crown down a few inches into the valleys to level things out. Should I set my disc to be aggresive or least aggresive?
/ Leveling ground with disc #2
I would just leave your disk set up however it already is and make a few passes over the problem area. Then get a log and connect a chait to either end of it to create a log drag so that you can smooth it all down. With a small 5ft disk and an oak log, I've been able to smooth out some very rough land.
Eddie
/ Leveling ground with disc #3
Slight bite on the front, and almost straight in the rear. Work shallow and at a good rate of speed. It'll be good enough to pull those 71s over.
/ Leveling ground with disc #4
Lab, drag ridges w/blade-grade box to valleys. chop ridge and repeat if neccessary.I don't kwow what kinda ridge you got?(get pocket eye level cheap home depot) W/pocket eye level gota get low to ground to look/check.when look good, then drag whole field w/rr-rail iron. make sure your valleys are not natural drains.You may cause unatural sink-hole looking standing water by filling valleys? my2cents:) Also chain link fence makes nice smth/finsh job. valley fill make take 1yr. to settle/pack try to seed w/something right-away.
Got it fixed. Thanks!
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2012 Hyundai Sonata (A62679)
2012 Hyundai...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
2022 EZ-GO ELITE...
