Leveling an Arena....
/ Leveling an Arena.... #1
meledward23
too close to Graceland....
1025R
Well color me stupid.... But I am still trying to figure this one out. I have worked with professional graders for 10 years. Unfortunately their machines and mine work a little different. I just cant get this down.
I have an indoor horse arena. 60x120 feet. It has high and low spots. I have tried blading it, a double wheel pulverizer, and discing it. So far I cant get the high spots out (or it may be the lows that always stay).
Anyway I try and adjust the 3 pt to dig into the highs and lift out of the lows. This seems to work the best, but invariably I am always early on the dig and late on the pull up.... Obviously when the tractor goes up and down and I dont adjust the 3PH I just move the high lowes around. It's not just moving fluff sand these are packed mounds....
And is that draft lever actually do anything. I have yet to notice a difference when I have it on max and none....
Any useful suggestions welcome....
/ Leveling an Arena.... #2
I am no expert but I would try:
1)Taking the boxblade and loosen the packed mounds.
2)Use my disc and drag a heavy fence post, or 6" plastic pipe 5 or 6 foot long fill with concrete, heavy piece of angle iron, behind the disc.
Go back and forth, across and angles.
3) Use your tine harrow to smooth once finished with disc.
4) Drag a section of chainlink fence for final smoothing.
At www.horsestalls.com they have arena rippers and harrows.
You may also look at TBN's new site horsesbynet for opinions.
/ Leveling an Arena.... #3
Had the same problem at my place. I used my box blade (no teeth used) and kept passing over the high areas and dragging the excess dirt into lower spots. I set my box blade in a fixed position where it caught the high spots well but would let the excess dirt trickle out from underneath. This procedure took about half a day but I finally ended up with a nice smooth arena with no high spots. The dirt in my area is a sandy, red clay.
/ Leveling an Arena.... #4
best thing I ever got for leveling was a wheeled drawbar box blade. It sets back from the tractor on a long tongue and height is adjusted with a remote cylinder. It is far enough back it not affected as much by the tires rolling over high/low spots. It cut the time in half (at least) that I spend smoothing my driveway.
/ Leveling an Arena.... #5
How about putting some gauge wheels on your box blade? Quite a few members here have done that with rather good results. There is an active discussion about that here.
/ Leveling an Arena.... #7
I too had this problem after having the arena installed at our horse boarding facility. We have a lot of english riders and very concerned about the constant depth and level-ness of the arena. We have a compacted base with 3-4" of sand on top. It is a 100x200 arena with lights that I put in a few months back. I tried everything then bought the millcreek spin-groom 6' with the rake, our local JD dealer sold them. I don't have much time to mess around with the arena or desire too, but the spin groom works the sand perfectly, level and smooth everytime with just a few passes. I found many other groomers that were very expensive and may do a much better, faster job, but the spingroom works great for me and the price was right. If you are ever close to MD come by for a test run. Owen.
/ Leveling an Arena.... #8
One of the problems with a three point hitch attachment and trying to level ground is that as the tractor moves over the undulations, so does the implement. That is why a wheeled/towed type blade is much more effective.
We actually had our arena leveled via a road grader. Gave the operator three roosters and he graded our drive and arena. Now that is a deal you can't beat! /forums/images/graemlins/grin.gif
Thanks all.....
Well I have jsut about all the toys and gizmos mentioned. Only one of the arena aurfacers mentioned that I dont have. I dont forsee it doing anything differently than my others. Dragging an areana is easy enough. My indoor arena is 15 years old and the subbase is out of alingment. I tried earlier this year to drag all the sand to the center and then blade the high lows on out. Looks like I am going to suck it up and do that again. Probably about the only way to get this thing level again.
My main outdoor arena is about 15 years old and has none of the problems the indoor has. Has been flat since day one, and still is. It is just about 15" lower now than it was 15 years ago. It would be a nice farm if it werent for the horses always tearing things up...
/ Leveling an Arena.... #10
I had the same problem and I got a Hoelscher RB-6R with a wheel kit. It worked good because it works independent of the tractor. You don't get the affect of when the front of the tractor goes down the scraper does not go up. Check it out at www.hoelscherinc.com Commercial Products.
Hope this helps!
/ Leveling an Arena.... #11
We just installed an out side arena 80 x 100ft using 135 tons of sand. I tried everything I had to level the arena and saw an old post using a box blade with the scarifiers backwards. I leveled the box blade side to side and took the top link and adjusted it to raise the back of the box blade 6". I used the scarifiers in the front as a gauge and made a perfect leveling machine. I was tickled to death how well and how fast if was to level the arena. I guess it would work on any material.
Malvern
/ Leveling an Arena.... #12
I use a 3 pt cultivator with a section of drag harrow behind it for grooming.
For leveling, it's hard to beat multiple passes with a FEL and blade - and LOTS of patience.
We've got a 100x200 dirt arena where our front yard used to be. Now we just need to fence it in...
LAXPatrick
/ Leveling an Arena.... #13
meledward23,
The draft lever is not going to do anything unless you pull the draft control pin on your tractor...check your manual. I have yet to try box blading with draft control enabled. I think it would just complicate things.
Regarding the leveling problem, you are going to have to do this backwards. By that I mean you will have to be pushing dirt instead of pulling it.
I brought my tractor into my garage and lowered the box blade until it was just above(1/2") ground level. I moved the slider on the 3pt. lever to mark where this point is. Now find a level spot in the arena and lower the blade to the level you had marked earlier. Remember you will be backing up to the high spot you want to get rid of. Now start slowly backing up towards the high spot. You should be pushing little to no sand until you get to the high spot. The box blade will get to the high spot before the tractor will and should start pushing the mound. If the sand is packed your box blade will probably just ride up the mound, so you would need to loosen it up first.
I don't know how big the mound is but if it's wider than your box blade, I'd work the sides of it then work towards the center. When you make one pass you ought to see some progress where your blade made a pass.
I hope you figure this problem out with the equip. you got. If you do, don't forget to fill us in on the details.
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 HINO 195 18FT...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
2011 Nissan Juke AWD SUV (A64557)
2011 Nissan Juke...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
