Flail Mower Let's talk flail mowers
   / Let's talk flail mowers #4,901
Caroni mowers can be adapted for front mount use. Not sure if it is a specific model or more likely some adapter hardware but they showed one in their catalog a while back.
I saw that in one of their brochures...not sure if that was on the Caroni website, or linked from Agri-Supply.
Since the mowers we own are also sold in Europe, there are a number of attachments/implements used on the front of European tractors that are normally rigged to the rear of American tractors.
   / Let's talk flail mowers #4,902
Yes. I hope that front mounted flails become more popular and readily available in the USA. I suspect (no data) that our predominant use of rear mowers relates to habits that make sense for farmers but not so much for those of us just mowing our fields. A front mounted mower would be much easier to guide accurately and probably save time and fuel because less overlap would be necessary. It would also be more comfortable when mowing near obstacles as we wouldn’t need to twist around to see where the mower was.
   / Let's talk flail mowers #4,903
I put on the new duckfoot blades yesterday but here are a few pics that you asked for.
How long did you wind up waiting for your F rotor Caroni to swim over? & how much extra did agri supply charge vs the B? Given they seem to have just raised their prices by 330 today & I remember a mark-up for the special order being discussed earlier ... I knew I should have invested in that Evelyn Wood speed reading course back in high school. These 491 pages have just cost me at least 10 times what they wanted to charge back then.
   / Let's talk flail mowers #4,904
It was simply a blade swap and did not have to use the F rotor. The duckfoot blades are as wide as the back to back Y blades and the length is very close. They give a smooth clean cut without any gaps of uncut grass between the blades.
I've probably mowed close to 30 acres total so far and the blades are still in perfect condition. Keep in mind that I've not mowed any rocks or heavy brush. Everything has been pasture type grass with assorted weeds. I'm very satisfied with them so far.
I ordered 30 blades ( DFM-2042 ) from Flailmaster. Total cost was $127.34. I only needed 28 but wanted to have a couple spares on hand.
   / Let's talk flail mowers #4,905
Thanks houser52. I confused myself (happens a lot more often these days than it used to). I thought that blade attachments on the B's were 180 degree offsets on the rotor & the F's were 90. When I saw 90 degrees in the blade pic on page 484 it confused me. Maybe just bleary after reading all the posts. I'll be picking up my trailer & tractor next week, so may stop into an ASC while on the road & check out the Caronis. Thanks to all for the info/data/opinions. This thread may be a bear to wade through, but it's given me a lot to think about. As long as I'm already driving myself to the poorhouse with all the new toys, I figure I might as well slow down & leave a nicer path behind me & a flail sure seems more attractive than a bush hog + finishing mower. My old craftsman 42 rider can still handle the tight areas for lawn mowing, but it would sure be nice to reduce my 4 hours of mowing every 10 days by getting something with a 6 ft swath & it'll save wear on the craftsman deck in the tougher areas of "lawn". Seems the flail will also let me open up my fence lines & clean out some trails in the woods. Now for the pond banks ...
Alex
   / Let's talk flail mowers #4,906
Alex
Another great thing about my flail is the 6' cut. You wouldn't think that an extra 12" of cut compared to a 5' hog would make much of a difference but I'm here to tell you that it does! That extra 12" probably saves me an hour each time that I mow compared to the 5' brush hog when mowing the same area.
   / Let's talk flail mowers #4,907
I've been following this thread for some time now and reading about belt problems and other issues. Also, I have researched flail mower prices. I recently purchased a 68" flail mower from Titan Attachments, free shipping, attractive price under $1400.00, delivered to my door.
It is of Chinese manufacture and looks to be a copy of popular European brands. It weighs about 675 lbs and is well constructed, thick steel plate, good welds, easy to use and doesn't chew up belts. The 68" uses three drive belts that run cool regardless of load. It came with duck foot fails, just what I was looking for.
I am usually skeptical of Chinese manufactured stuff having made several trips to China for manufacturing services and to purchase machinery. If you are careful, you can get good deals and reliable products. The Titan flails are good. I have used mine for cutting weeds and brush containing some 3 inch limbs and roots from recent clearing. My 45HP M-F handled it well with no stalls, no belts burning and nothing broken. I got some hidden fence wire wrapped in the rotor which might have caused issues with other brands. I cut six acres and some brush was over the hood of the M-F in height.
I found the following;
1- Keep the side skids at a low setting for initial field work. Mine are down the max.
2- Using the top link, raise the front of the mower so that the rear roller engages the ground. Much better cutting this way and clumping is reduced.
3- My mower allows installation of the top link tower with or without offset. I have no need for a hydraulic side shift using the offset setting. Plenty of reach when mowing next to trees and fences.
Some comments regarding Titan; Excellent service, tough flail mower (although, I have no experience with other brands), easy to use and maintain and a great value.
I'll likely sharpen my duckfoot flails over winter due to some contact with rocks. The originals are forged steel not the bent style. They'll last for many years with some occasional sharpening. This will also improve the mulching performance of the mower.
As for power, I mowed my 6 acres in a day with one stop to untangle the wire caught in the flail drum. I believe a 30 HP machine could easily handle this flail especially for routine mowing. First time cut in a rough field might take more time at a slower speed. Keep the PTO speed at or slightly above the 540RPM. Remember too, flails are much easier to maneuver around objects due to their smaller footprint. They are less prone to throw objects, quieter and store inside a small shed. I'll likely pressure wash and repaint the underside in a year or two.
   / Let's talk flail mowers #4,908
If you purchase a slow speed wet well grinder from Micro-Mark - The Small Tools Specialists They were on sale for less than 90 dollars at one point.
I have not looked lately at their current price but you will be able to maintain the cutting edge with a cool grind without damaging the forging.
   / Let's talk flail mowers #4,909
   / Let's talk flail mowers #4,910
My mower allows the sharpening of the flails in situ. I'll use my angle grinder for sharpening. They'll only need a touch up...not a lot of heavy metal removal.
TRANSMISSION JACK (A55745)
TRANSMISSION JACK...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2016 Ford F-150...
KIDS DIRT BIKE (A53424)
KIDS DIRT BIKE...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2025 20-Drawer Workbench Toolbox (A55788)
2025 20-Drawer...
2016 Chevrolet Impala Limited Sedan (A55853)
2016 Chevrolet...
