Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #7,681
Long time no talk flail fellas...been too busy working.
Someone sell me on a ditch bank mower.
My little 4ft Ford flail has been doing a bang up job with my Yanmar 2420D but I'm getting into projects where I need a bigger tractor. A 48" cutter has worked great on a 50" wide tractor but all my potential replacements I'm considering are 60"+, one pushing 72".
Add in that I have an 1100 ft long terrace line that's a royal pain to keep cleaned up. Towards the back of my property the terrace is nearly a 10ft drop steep enough that my only option has been roundup and forget it.
Make some suggestions for me. I'm looking at new equipment this time around. I'm tired of working on stuff before I can work on stuff....
My solution for my ditch bank ended up being a three point mounted disk mower. I got a heck of a deal on a used one. I use it for making hay and mowing my ditch. It's designed from the start to hang off to the side and only requires 1 remote (to lift it). It weighs less than a comparable flail, and cuts as fast as you can drive. Granted it won't take down brush like a flail will, but it maintains grass very well. It also uses a bit of horsepower, so keep that in mind. A drum mower would likely do the same with less HP, but I don't have much experience with those. And, from what I remember, most drum mowers swing to the rear for transport instead of lifting up. A good option if you don't have a remote to use. But from what I can remember, drum mowers tend to be shorter in length than disc mowers.
When looking for a disc mower with intentions of running it at an angle look for one with individual pods and grease instead of oil. I have an older New Idea mower that has these features. The oil filled ones will lose oil from the more elevated areas and wear prematurely when run at an incline for extended periods.
/ Let's talk flail mowers #7,682
New tractor will be here this week, so I think I'm going to see if I can run it down that slope. New one is 2ft+ wider than the old one and not much taller so it may be stable enough. If it is I may just get a bigger normal mower, or possibly one with hydraulic offset....
/ Let's talk flail mowers #7,683
Anybody know anything about chambers American flails? 90" for fairly cheap nearby. I can't find a whole lot googling though
/ Let's talk flail mowers #7,684
Local dealer said they didn't know when or if they'd get another shipment of Del Morino anything and couldn't guarantee they'd get me a flail. They showed me some Titans when I initially thought were the chicom units but now that I'm looking online, it appears they have some pre-name change Ironcraft. My understanding is those are Italian as well correct? Cosmo? In stock FL-165 was quoted as around $3600. Really need a 6ft unit though.
sigh, may just end up getting another used one. As much as I'd like to have a whiz bang new one, not sure I can justify it....
/ Let's talk flail mowers #7,685
I would check with another Del Morino dealer or the nearest Maschio implement dealer as the
usual turn around is 6 weeks between order placement and a container coming from Europe.
/ Let's talk flail mowers #7,686
What's your opinion of the Ironcraft/Cosmo? They did say they could probably get one of those fairly readily.
/ Let's talk flail mowers #7,687
Hello and good morning nova3930,
I ask that you bear with me as I had 5 teeth pulled yesterday and it takes longer to do chores.
The COSMO implements are made in Italy and come under the European Unions safety and
construction standards.
The propain people are here and I have to go.
/ Let's talk flail mowers #7,688
No worries man. Take care of yourself. Don't kill yourself correcting my ignorance lol
/ Let's talk flail mowers #7,689
10:30AM Eastern Standard Time
No worries;
You are not ignorant my dear friend, you are in the process of buying a (very safe to use around 2 legged and 4 legged rug rats)
flail mower/crop shredder that will last you through several new mules.
It is $2,500.00 later and I will have a new propain water heater this afternoon.
When you get further along with this today tell me which model you wish to buy
before you pay for it as you will have to decide what options you want with it.
/ Let's talk flail mowers #7,690
Would probably be the FMH-175 if I go that route. It's either that or find another old Ford/Alamo/Etc, although I do like the look of the Chambers American I found. They're still in business they just don't do 3 pt implements any more, they have their own specialized mower carrier they build....
I can't really buy a new one till I sell the old tractor anyway though.
/ Let's talk flail mowers #7,691
AHHHHH,
The major decision for you will be whether you want side slicers or the cast hammer knives
as the flail mower/crop shredder comes with hydraulic side shift as standard equipment.
Leon
/ Let's talk flail mowers #7,692
Hey Nova,
I have a titan(now iron craft) Italian flail it has held up well for my 3 years. Bolts tend to loosen so have to check regularly. And I have been rough with it. otherwise it has been goood value
/ Let's talk flail mowers #7,693
Hey Nova,
Appreciate the feedback
/ Let's talk flail mowers #7,694
AHHHHH,
Leon
Local place quoted me $4500 on one. They're getting lead time Monday. Another place further out had them in stock but was around $5500....
/ Let's talk flail mowers #7,695
I guess it may be worth asking if your local dealer could buy it for you and trade one of thier inventory implements
for it just like they trade vehicle stock between dealers.
/ Let's talk flail mowers #7,696
Possibly. I don't really need it immediately though, it is past grass cutting season after all....or at least I refuse to cut grass past september....
/ Let's talk flail mowers #7,697
Well, first place couldn't get a lead time from manufacturer. Another place, again a little further out, quoted me $4200 with it in stock. Long as my mill sells this evening guess I'm road tripping later this week.
After I looked I asked about the two bigger fmh units since I've got plenty of HP to run them. Not in stock with no lead time again though.
/ Let's talk flail mowers #7,698
Is a used John Deere 25A, 290 or 390 out of the question??
/ Let's talk flail mowers #7,699
Shoot if I could find one.... There's a pretty new 25a not far off from my childhood home. My pops might could go get it.
Course I like the idea of having at least one new implement I know doesn't require work prior to the main job of the day....
/ Let's talk flail mowers #7,700
I would ask your dad to take a look with cash in hand if at all possible as parts are
still available and they are very easy to maintain and repair if needed.
The 25A that my dad had was a great mower. His tractor the 1953 Ford Jubilee had
a 6 volt electrical system that gave him fits.
He mowed in 4 acre blocks every two weeks to keep the pasture free of weeds.
SHOPBUILT S/A TRAILER FRAME (A64278)
SHOPBUILT S/A...
S/A Tropic Trailer (A64557)
S/A Tropic Trailer...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2015 FREIGHTLINER...
JOHN DEERE C6R36" CORN HEAD (A64278)
JOHN DEERE C6R36"...
Lot of 2 ForeRunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Lot of 2...
