Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,522
I operate a five foot New Holland 918L flail with a 2011 Kubota B3300 (33 engine Hp), I mow a 5 acre field with various pasture grasses. Unfortunately, it does not cut some of the tall (2-3 ft) grasses well, essentially rolling them under and then they pop up. Even a second pass will not always get them. I'm no expert, but I think it is orchard grass, with its tough stem, that is the main culprit. I tried sharpening the knives this past winter (about 200 knives, I think), but no improvement. I am operating the tractor as sufficiently slow speeds in the heavy going, and the mower does not operate under strain at the slow speeds in these heavy patches. So what I am beginning to think is that this mower is just a finishing mower for light grasses and lawns. Am I correct? Is the HP of my Kubota a factor (I wouldn't have thought so for this light flail)?
Is a medium flail the answer? I don't need to cut brush, just pasture grasses. I'd like to get a 73" model and am wondering if the 33 HP is sufficient? I am aware that Caroni makes one that they recommend for 30 to 60 HP, but I don't know if that is the power at the PTO or the engine, and I don't like to have a tractor at the low end of the range. Any ideas about my problem and suggestions for an appropriate flail will be much appreciated.
I have a 7' 719 behind my 32hp L3200. My only problem when cutting my hood high pasture/field was my tire tracks. Lots of the tire tracks stood back up after cutting. Everything else was good though.
I don't have a lot of tough stuff, but the little bit of viney & weedy stuff I cut hasnt been a problem. Never encountered Orchard grass, so can't say if it fails to cut or not.
/ Let's talk flail mowers #2,523
I just picked this unit up and wanted to share a couple photos. The farmer that had the unit operated it as I watched and was helpful as I checked the bearings, roller, belts and the unit. I purchased the unit and he had a full set of replacement knives and a few rings I got with the unit.
The only concern I have is the skid plates are missing as well as a couple of the bolts on the pulley cover. Unit had very little vibration and mowed the grass well.
I have the owners manual but am thinking I might want to find a service and parts manual.
What would you do to get this unit ready to mow and does anybody have an idea of what the skid plates cost?
Thanks!
/ Let's talk flail mowers #2,524
Thanks!
Hello freeborn,
I want to welcome you as the newest member of the Flail Mower Nations.
There is no Passport required at the beer garden border crossing.
First things first,
You can obtain parts manuals and operating manuals from the various JD parts stores on the internet.
You can get the skid plates from them as well.
Does this 25A model have three rows of scoop knives or four??
My fathers 25A had 4 rows of side slicer knives for a finish cut
Please tell me now if possible.
You have a nice mower there that needs a bit of work but well under $700+-
if you count the new PTO shaft, drive belts, antiscalp skids and replacement bolts
for the V belt guard. A 25A these days is well above $9,500.00+tax if you want
a 25A finish flail mower.
You have the "scoop knives" some times referred to as shovel or duck foot blades.
Scoop Knife is the proper term not that its an issue.
The D ring hangers are what the scoop knives are attached that are attached to the "Flail Mower Rotor"
which is what the D ring is attached to with the strap that holds the D ring which the scoop knife is attached to.
You need a supply of new D ring straps and the nuts and bolts and washers (buy the fine threaded ones and some blue loctite to secure the nuts-You should buy the allen bolts as that will prevent a lot of scraped knuckles and contributions to the swear jar.
You can get almost everything you need at flail master or clean cutter. I do not remember if you can purchase the JD mower skids from them-you need them to keep the mower from diving into the ground while mowing and hitting dip
Your 25A can handle brush mowing and finish mowing but will give you a coarser waffled
cut on good sod.
Buy new Belts, the Kevlar green belts are better for absorbing shock loads, change the gear oil, no more than six pumps of grease inthe flail mower rotor bearings, make sure the rear roller bearings can take grease (five pumps at each mowing)
YOU MUST remove the V belt guard and scrape all the rubber and grass duct from under the guard to expose the grease fittings and also be sure the spring tensioned V Belt tensioner moves freely.
They removed the mower skids to lower the mowing height NOT GOOD EVER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.
The four adjusment holes above the single bottom hole in the side welment are how this flail mower is adjusted for
mowing height.
When you get the new PTO shaft you mak have to cut it to the right length.
You do not have to buy a new PTO shaft with a friction slip clutch, the V belts are
your slip clutch as they will burn up and prevent damage to the flail mower.
MAKE SURE the lower links are equal length and locked in place before you mow with it.
Get the new skids lower the rear roller one bolt hole ON BOTH SIDES and then level the flail mower with a torpedo on the gearbox using ONLY the top link adjuster.
Welcome to the Flail Mower Nations,
Happy Mowing
/ Let's talk flail mowers #2,525
Thanks Leonz,
The unit has 3 rows and I do have the other half of the PTO shaft. The unit is a little rusted but seems in solid condition. I need to spend some time looking at the scoop knifes as they look pretty good at first review. I know you recommend a sharpener, what is the brand and can you recommend a source?
Great thread and thanks for the advice, I'm looking forward to operating the mower.
I paid $900 for the mower so I thought a fair price.
Thanks again.
/ Let's talk flail mowers #2,526
Hello freeborn,
I recommend a well well grinder for them as they offer the best way to keep the
temper on the knives as most of them are hardened.
There are a bunch of them for sale and you can buy good ones for under 100.00 the last time I looked.
Wen no longer makes the unit I bought many years ago.
/ Let's talk flail mowers #2,527
Thanks Leonz, The unit has 3 rows and I do have the other half of the PTO shaft. The unit is a little rusted but seems in solid condition. I need to spend some time looking at the scoop knifes as they look pretty good at first review. I know you recommend a sharpener, what is the brand and can you recommend a source? Great thread and thanks for the advice, I'm looking forward to operating the mower. I paid $900 for the mower so I thought a fair price. Thanks again.
I've found that wet grinders are painstakingly slow and make a terrible mess. A bench top or pedestal mounted high speed belt grinder will remove large amounts of material well before heat becomes an issue. If your knives require a really excessive amount of material removal you can rotate the knives or quench as you go. Get a low heat generating coarse grit ceramic belt and you are set. A Dayton 2" x 48" bench top belt grinder is what I use for all mower and flail blades with no discoloration of metal or loss of temper.
/ Let's talk flail mowers #2,528
If you have the time a wet well grinder is very good and slower
in speed to do the work. I just budget an hour or two when I
do them. I will probablypull all of them of and touch them up if they need it.
I am not happy in knowing I can no longer buy the tapered side slicers.
/ Let's talk flail mowers #2,529
Caroni owners -- has any body tried a drilled pin and kotter vs. the bolts and lock nuts for their knives? I am not looking forward to wrestling with 56 of these while under the mower.
/ Let's talk flail mowers #2,530
Hello Louie Junior,
The issue is the metric parts, its easier to use a right angle
air wrench if you have access to one. The thing is that your
going to spend as much time or more with METRIC cotter
pins and the drilled dowel pin which is its mate.
if you can wash the underside with pressure washer it will be
easier as the threads will have less dirt and grass dust in them.
The thing is that that the drilled dowels head is very unforgiving
unless you have a monster vice grip on a clean pin.
Perhaps its better to think ahead and replace the bolts and nuts with
metric fine thread hex head cap screws(allen bolts) and nuts and blue Loctite
using a metric allen head bolt will allow you to use a long metric allen wrench and
an air operated ratchet wrench and avoid making a large contribution
to the swear jar.
The bolts clean up easily with alcohol and a wire brush or an ultrasonic parts cleaner or a
die that matches the thread size and type.
Bolts and nuts in bulk being one hundred to a bag/box are very economical in
the scheme of things.
An air ratchet will speed things things up for you and flipping the mower over will not hurt things-just check the oil and add oil back before using it again.
/ Let's talk flail mowers #2,531
An air ratchet will help but you need a very good quality ratchet. The cheap version from HF definitely does not have the guts to remove the old bolts/ nuts that have damaged threads from mowing.
I use two manual ratchets. One with socket and the other a ratcheting flat wrench. There isn't space to use two socket wrenches. I also use a piece of pipe for more leverage as backing off the nuts over damaged threads is grunt work and not just to break the nut free.
You have to get the tractor/mower in a good position as you need to be reasonably comfortable and get good leverage. I back my tractor up the ramp to my barn and work on the mower fully lifted and with topping link short. I stick a couple of 2x4s under for safety and sit on a short stool just behind the mower so I can comfortably get both arms under with good leverage. PITA to be sure but that is the most efficient way I have found to do it when changing several at a time. I guess if I were to change them all at once I'd dismount the mower and turn it over but I'm sure the oil would leak out of the vented oil cap then.
/ Let's talk flail mowers #2,532
When sharpening knifes is it always necessary to remove them from the mower? Do you ever just touch them up on the mower rather than taking them off?
I plan on using the mower to cut Prairie Grass. The mowing will occur either in late fall or early spring when the grass/thatch is very dry and the actual grass should be dormant. I live remotely from my property so its not easy to get time to work on things but maybe its an annual even where I bring the blades home with me. Still it would be nice to be able to touch up knifes on the mower when you need to.
/ Let's talk flail mowers #2,533
Hello Flail Nation
I have recently purchase a few used alamo flail mowers, a gk74, a shd74, and a shd88. I have already changed the blades on the shd 74 from a light stamped to a 3.8 oz knife and like the results for mowing lightly over grown stuff with it. On the shd88 i am having a tough time in deciding to use the 3.8oz knives or go with the heaver 6.4 oz knives. I will be mowing mostly light brush and grass with the occasional batch of sapplings of up to 1". how much better would the 6.4 oz knives handle the sapling compared to the 3.8 oz. thanks for the advice in advance!
/ Let's talk flail mowers #2,534
About your knives, invest in an less costly wet well grinder to maintain the edge and avoid burning the knife and destroying the temper in them as too heavy a hand will damage them. The nice thing abou the wet well grinders is they run slowly and the water bath cools both the wheel and the knife at the same time. In this way you simply hold the knife with a light pressure along the angle guide for the cutting edge. If you are unsure what angle to set the toll holder at jus purchase one
new side slicer or scoop knife an use a protractpr to find the cutting angle of the side slicer or scoop knife.
I still have good edges on the knives I installed in 1992 for what its worth.
/ Let's talk flail mowers #2,535
Hello Flail Nation
The heavier the knife the more mass you present to the brush/saplings.
The other thing to keep in mind is to reverse over brush clumps to make your first pass as
the rear roller will knock them down and hold them there as you back over them.
Island tractor has some beautiful before and after pictures of brush clearing doing it in
this way on his farm.
As long as you mow "very very slowly" over the brush clumps you will shred everything in small
pieces. If you encounter saplings turn around and mow them down in this way and you will
have no issues.
If you can mow them down when they are deadd/dormant all the better as they wil have dried out quite a bit too.
/ Let's talk flail mowers #2,536
I forget the exact weight of the knives on my Caroni TM1900 but I'm pretty sure they are a few ounces each and certainly not 6.4 oz. That said, my knives do a fair job with brush up to about an inch. Makes a lot of noise but it mulches the saplings pretty thoroughly. I might go for heavier knives/hammers if I were primarily doing brush/sapling work.
/ Let's talk flail mowers #2,537
WOW,,,,, you haven't had to sharpen your knives in 23 years???
I must have read that wrong........... So how many hours a year do you put on your mower????
/ Let's talk flail mowers #2,538
Leon, I assume you remove knives for sharpening. My SHD88 has 208 knives on 104 stations. Each is held on w a 1/4" bolt/nut. I have to sharpen at least once a year to cut 8 acres of mostly grass. Takes several hours just for the R&R. You got a secret hard knife you're not telling us about?
Jim
/ Let's talk flail mowers #2,539
Hello Jimmy,
No secret hard knive or secret handshake to identify our flail nation members-(nor lists kept to identify the members and I dont need the black helicopters finding the right people with the right mowers!!!
Hades!, they had enough trouble with the blimp yesterday and today and they shot it up with a shot gun and lost all that good helium!!!!!!!!!!!!!!!!
The Lawn genie flail mower rotor has a tool free mounting system with a spring latch-dont worry I am working on that issue for everyones benefit too.
I am also working on the knife side of things too in order make things easier for the fellow members.
We always kept a complete spare set on hand to change them out 64 stations 128 knives-not including the 64 dethatching blades.
Dethacthing really dinged the side slicers as pop never removed them when he dethatched the 4 plus acres every year.
/ Let's talk flail mowers #2,540
WOW,,,,, you haven't had to sharpen your knives in 23 years??? I must have read that wrong........... So how many hours a year do you put on your mower????
I've never sharpened mine in eight years but I lose them regularly in our rocky soil so I'm not sure I have a single original blade set left.
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
