Lessons learned
/ Lessons learned #1
Latis
After much research about compact tractors, I decided on a Yanmar 2000BD. After reading this forum and talking to many ‘dealers’ I decided to purchase a reconditioned tractor and rotary cutter from Fredrick’s Equipment in Alabama. I live in Washington State.
The tractor was shipped via a third party carrier. Although I was promised delivery to my door, it was my responsibility to remove it from the back of the enclosed trailer. It arrived at 9PM and it was finally unloaded at midnight. Fredrick’s did their best to protect the tractor in a steel frame crate, but it was a little beat-up. Paint was scratched and some minor parts missing. Called Fredrick’s and they sent me the missing parts and some paint.
Lesson 1: When using a third party carrier ensure the tractor is shipped in a fully enclosed crate.
After mowing the field for about an hour I started to hear a high pitch squeal. It turned out the brakes were adjusted to tight (no free-play).
Lesson 2: Always check every adjustment possible. Never assume it was done correctly.
Another hour of mowing and I noticed oil on the inside of my front wheels. Called Fredrick’s and they sent me front wheel seals.
Lesson 3: 28 year old tractors should have new front wheel seals.
My next problem was the clutch. No matter what adjustment I did, it would always grind when put into gear. Called Fredrick’s and they told me to split the tractor because the pressure plate might have broke. So I split the tractor and found a new clutch, new pressure plate (undamaged), old throwout bearing, and damaged pilot bushing. Fredrick’s sent me a new thowout bearing and pilot bushing.
Lesson 4: If the clutch and pressure plate is replaced, the throwout bearing and pilot bushing should also be replaced.
A month later the engine started to run hotter and the antifreeze level was low. I then found a crack in the radiator around the cap. Called Fredrick’s and they told me to simply solder the area. Before I got around to fixing it, to my surprise a new radiator arrived -courtesy of Fredrick’s Equipment.
Bottom Line: Stuff happens. Unless your dealer is close by, be prepared to get your hands dirty. Don’t expect a 25+ year-old tractor to be perfect. Buy a tractor from a member of the Used Tractor Dealer Association (www.utda.net) - they stand by their tractors.
/ Lessons learned #2
I get a couple emails a day asking me why I won’t ship tractors outside of my service area, some are even quite upset and rude about it. I have a small canned response that I usually reply back with but I think your post would almost work better. Can I use it?
Buck
P.S. Fredrick’s does a great job and is a great place to buy a tractor.
/ Lessons learned #3
I have had both........ A Vietnamese reconditioned Yanmar, and a U.S. 'reconditioned' Yanmar.
I have had problems with both........
With that said, I didn't put but about 20 hrs on my Viet recon before I traded it for a 4x4 truck. (I did Not get rid of it because of the problems....It was just too small for me.) It kept overheating:mad:. My radiator enden up being 50% (estimate) stopped up, but the dealer took care of the costs (and would've on the labor, but it was in another state). Another potential problem, just before I got rid of it, was the starter. Sometimes it would "catch" the gear on the flywheel (to spin over the engine), and sometimes it wouldn't. You had to 'play' with the ignition.
I have put about 37 hrs. on my U.S. recon, which was (also, like yours) processed at Fredrick's Equipment (BUT I DID NOT DIRECTLY PURCHASE FROM THEM), with an ongoing hydraulic problem (as we speak):mad: This has really been my only problem wih that tractor, but is Very bothersome. But hopefully that is fixing to be solved when I get it back together. Fingers crossed...:(
The UTDA member that I purchased from, here in Louisiana, was alright but should've completely took care of my hydraulic problem. I spent a lot of money there. NO IFs, ANDs, or BUTs about it.
I was aware of "getting my hands dirty" when purchasing a used Yanmar (or any other brand for that matter) tractor...... But I wasn't prepared to get my head, elbows, and leggs covered in grease and oil though! lol!:p:D
Travis R
/ Lessons learned #4
I know my dealer is not a member of the Used Tractor Dealer Association . And I get real good tractor at a good price. .My dealer dose OK. And it has never been painted it look like it did in Japan. and my hydraulic is not bad. and my 3pt will stay up all week on all three of them.
/ Lessons learned #5
Travis R
Travis,
I'm not following you.....What exactly did the dealer do, or didn't do?
/ Lessons learned #6
Gismo is that your 3110 in the picture?
It sure looks nice, I have a 24x36" poster of a new 3110 with a farmer sitting on it in Japan. Looks just like the one you posted.
Ernie
/ Lessons learned #8
I think the biggest lesson here ( atleast for me) would be not to buy a tractor without actually viewing the tractor in person and checking it out before the check is written.
I do however realize this is not always possible for some people though. it sounds like the dealer was doing all he could to make things right.
2023 Giant G2500HD Mini Articulated Wheel Loader (A66734)
2023 Giant G2500HD...
2013 International DuraStar 4300 S/A Dump Truck (A66736)
2013 International...
CAT 740 Engine (A68134)
CAT 740 Engine...
AIR OPERATED OIL PUMP APROX 200 GALLON TANK (A67714)
AIR OPERATED OIL...
213063 (A64276)
213063 (A64276)
Yamaha EF1000iS Portable Inverter Generator (A66734)
Yamaha EF1000iS...
